wildfireone 0 Posted May 17, 2019 Posted May 17, 2019 Hello, I seem to be having issues with Metadata, Initially I was having issues with 4.1.1.0, however have set up a clean install from plugins so back on 4.0.2.0 and still seem to be getting an issue after restoring the database: 2019-05-17 13:37:02.513 Error ProviderManager: Error in metadata saver *** Error Report *** Version: 4.0.2.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd_{version}_amd64.txz Operating system: Unix 11.2.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Fri Apr 26 05:09:11 UTC 2019) Processor count: 24 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.MissingMethodException: System.MissingMethodException: string MediaBrowser.Controller.Library.ILibraryManager.GetPathAfterNetworkSubstitution(System.ReadOnlySpan`1<char>,MediaBrowser.Model.Configuration.LibraryOptions) at NfoMetadata.Savers.BaseNfoSaver.AddImages (MediaBrowser.Controller.Entities.BaseItem item, System.Xml.XmlWriter writer, MediaBrowser.Controller.Library.ILibraryManager libraryManager, MediaBrowser.Model.Configuration.LibraryOptions libraryOptions) [0x00017] in <20c314253b1c44cc8bd4fb638a40bec0>:0 at NfoMetadata.Savers.BaseNfoSaver.AddCommonNodes (MediaBrowser.Controller.Entities.BaseItem item, System.Xml.XmlWriter writer, MediaBrowser.Controller.Library.ILibraryManager libraryManager, MediaBrowser.Controller.Library.IUserManager userManager, MediaBrowser.Controller.Library.IUserDataManager userDataRepo, MediaBrowser.Model.IO.IFileSystem fileSystem, MediaBrowser.Controller.Configuration.IServerConfigurationManager config) [0x00b37] in <20c314253b1c44cc8bd4fb638a40bec0>:0 at NfoMetadata.Savers.BaseNfoSaver.Save (MediaBrowser.Controller.Entities.BaseItem item, System.IO.Stream stream, System.String xmlPath) [0x00063] in <20c314253b1c44cc8bd4fb638a40bec0>:0 at NfoMetadata.Savers.BaseNfoSaver.Save (MediaBrowser.Controller.Entities.BaseItem item, System.Threading.CancellationToken cancellationToken) [0x0000e] in <20c314253b1c44cc8bd4fb638a40bec0>:0 at MediaBrowser.Providers.Manager.ProviderManager.SaveMetadata (MediaBrowser.Controller.Entities.BaseItem item, MediaBrowser.Controller.Library.ItemUpdateType updateType, MediaBrowser.Controller.Library.IMetadataSaver[] savers, System.Threading.CancellationToken cancellationToken) [0x00100] in <3dd6cb4e99294cca81d77ebb6c7c6114>:0 Source: NfoMetadata TargetSite: Void AddImages(MediaBrowser.Controller.Entities.BaseItem, System.Xml.XmlWriter, MediaBrowser.Controller.Library.ILibraryManager, MediaBrowser.Model.Configuration.LibraryOptions) at NfoMetadata.Savers.BaseNfoSaver.AddImages (MediaBrowser.Controller.Entities.BaseItem item, System.Xml.XmlWriter writer, MediaBrowser.Controller.Library.ILibraryManager libraryManager, MediaBrowser.Model.Configuration.LibraryOptions libraryOptions) [0x00017] in <20c314253b1c44cc8bd4fb638a40bec0>:0 at NfoMetadata.Savers.BaseNfoSaver.AddCommonNodes (MediaBrowser.Controller.Entities.BaseItem item, System.Xml.XmlWriter writer, MediaBrowser.Controller.Library.ILibraryManager libraryManager, MediaBrowser.Controller.Library.IUserManager userManager, MediaBrowser.Controller.Library.IUserDataManager userDataRepo, MediaBrowser.Model.IO.IFileSystem fileSystem, MediaBrowser.Controller.Configuration.IServerConfigurationManager config) [0x00b37] in <20c314253b1c44cc8bd4fb638a40bec0>:0 at NfoMetadata.Savers.BaseNfoSaver.Save (MediaBrowser.Controller.Entities.BaseItem item, System.IO.Stream stream, System.String xmlPath) [0x00063] in <20c314253b1c44cc8bd4fb638a40bec0>:0 at NfoMetadata.Savers.BaseNfoSaver.Save (MediaBrowser.Controller.Entities.BaseItem item, System.Threading.CancellationToken cancellationToken) [0x0000e] in <20c314253b1c44cc8bd4fb638a40bec0>:0 at MediaBrowser.Providers.Manager.ProviderManager.SaveMetadata (MediaBrowser.Controller.Entities.BaseItem item, MediaBrowser.Controller.Library.ItemUpdateType updateType, MediaBrowser.Controller.Library.IMetadataSaver[] savers, System.Threading.CancellationToken cancellationToken) [0x00100] in <3dd6cb4e99294cca81d77ebb6c7c6114>:0 Could anyone shed some light?
Luke 42239 Posted May 17, 2019 Posted May 17, 2019 Looks like you started with a newer version and then went backwards to an older version. That's not supported and now you have incompatible versions of plugins installed.
wildfireone 0 Posted May 17, 2019 Author Posted May 17, 2019 Ah that would make sense, I thought I grabbed the right backup when reinstalling. What would be the best cause of action, try again or remove the plugins and reinstall?
Luke 42239 Posted May 18, 2019 Posted May 18, 2019 You could use the plugin catalog to install the latest compatible versions of all plugins until the errors in the log go away. If you still have issues after that then I would just reinstall. Thanks.
