mudbuddha69 11 Posted May 15, 2019 Posted May 15, 2019 i have a DIAMOND ATI Theater 750 PCIE HD TV Tuner Card (TVW750PEC) works fine on the server but emby can find it. is this card not compatible with emby ATSC, DVB-T, Clear-QAM Digital TV Support (unencrypted digital TV) PAL, SECAM, NTSC Analog TV Support Intelligent Image Enhancement 12-bit Resolution Audio and Video Decoder Software MPEG Encoding PCI X1 Interface F-Type coax connector for NTSC, PAL/SECAM, ATSC, ClearQAM and DVB-T S-video input with adapter Stereo audio input with adapter Composite video input with adapter 1
Spaceboy 2573 Posted May 15, 2019 Posted May 15, 2019 i have a DIAMOND ATI Theater 750 PCIE HD TV Tuner Card (TVW750PEC) works fine on the server but emby can find it. is this card not compatible with emby ATSC, DVB-T, Clear-QAM Digital TV Support (unencrypted digital TV) PAL, SECAM, NTSC Analog TV Support Intelligent Image Enhancement 12-bit Resolution Audio and Video Decoder Software MPEG Encoding PCI X1 Interface F-Type coax connector for NTSC, PAL/SECAM, ATSC, ClearQAM and DVB-T S-video input with adapter Stereo audio input with adapter Composite video input with adapter no. Emby only supports hauppaugge cards. You need to use a supported backend 1
Luke 42219 Posted May 15, 2019 Posted May 15, 2019 Hi, what this means is that you can add support by installing one of the live tv plugins in the Emby plugin catalog. This will allow you to use third party software to import the tuner content into Emby. Please let us know if this helps. Thanks !
