DamnedUndies 17 Posted December 31, 2019 Posted December 31, 2019 Thanks ebr, will do. Just so I understand: The HDHR Extend is enabled to do HW transcoding. Does Emby server also do some level of transcoding on top of this?
Luke 42244 Posted January 3, 2020 Posted January 3, 2020 Thanks ebr, will do. Just so I understand: The HDHR Extend is enabled to do HW transcoding. Does Emby server also do some level of transcoding on top of this? Hi @@DamnedUndies, sometimes. We do avoid it when possible, but it depends on what Emby app you're using, what the device supports playing, what your video quality settings in the app are, etc.
brettuk 1 Posted January 16, 2020 Posted January 16, 2020 Any update on this? It's a really annoying bug that means I can't watch recordings until they've finished airing.
Luke 42244 Posted January 17, 2020 Posted January 17, 2020 We are looking into this. Thanks for reporting.
Luke 42244 Posted January 24, 2020 Posted January 24, 2020 This is resolved in the upcoming 4.4 release of Emby Server. Thanks for reporting. 1
DamnedUndies 17 Posted January 24, 2020 Posted January 24, 2020 Thanks for the update, Luke. It looks like you just released the fix you mentioned in the 4.4.0.9 beta, right?https://github.com/MediaBrowser/Emby.Releases/releases/tag/4.4.0.9
bcm00re 18 Posted January 25, 2020 Posted January 25, 2020 Any idea when 4.4 (non beta) might be released? Just curious if it's close. 1
brettuk 1 Posted January 25, 2020 Posted January 25, 2020 Hey, I installed the beta, it's perfect now! The only thing, a pretty minor thing, is that it's possible to fast forward past live while watching a recording in progress, and the time remaining isn't accurate, but more importantly watching the recording in progress works perfectly, and I can fast forward through the ads! A very happy camper here. Thanks! 1
bcm00re 18 Posted January 25, 2020 Posted January 25, 2020 Can anyone point me to something that details how to install beta versions? I downloaded embyserver-win-x64-4.4.0.9.7z and already had something to extra it, but I'm not sure if I should just take all the contents and overwrite the existing server files or what. 1
brettuk 1 Posted January 25, 2020 Posted January 25, 2020 https://emby.media/download.html Click on your platform then click on the link for the beta channel
ebr 16337 Posted January 25, 2020 Posted January 25, 2020 Can anyone point me to something that details how to install beta versions? I downloaded embyserver-win-x64-4.4.0.9.7z and already had something to extra it, but I'm not sure if I should just take all the contents and overwrite the existing server files or what. Hi. We don't suggest installing beta versions just to get early access to new features or fixes so please be aware of all the implications that come with running a beta version (possible instability, errors, etc.). Thanks.
DamnedUndies 17 Posted January 25, 2020 Posted January 25, 2020 (edited) This is resolved in the upcoming 4.4 release of Emby Server. Thanks for reporting. Huge improvement! What a difference. Keep up the great work. Edited January 25, 2020 by DamnedUndies
bcm00re 18 Posted January 28, 2020 Posted January 28, 2020 (edited) Hi. We don't suggest installing beta versions just to get early access to new features or fixes so please be aware of all the implications that come with running a beta version (possible instability, errors, etc.). Thanks. Understood. I am a software developer myself so I get the concept/intent of beta code. So is 4.4 anywhere close to being released officially? I won't hold you to anything of course! Edited January 28, 2020 by bcm00re 2
