simonselmer 27 Posted May 15, 2019 Posted May 15, 2019 Hi Let's say I'm recording a 2 hour movie. 20 minutes after the movie starts, I'm ready to start watching it, from the beginning of course. 1. FEATURE REQUEST: I cannot start seeing the movie from the beginning using the TVguide. In MediaPortal, it was "smart" enough so if I play a show/movie from the TVguide, which MediaPortal knew is currently being recorded, it would "of course" jump to that stream already being recorded. And I would be prompted to select "start from beginning" or "start from now". In Emby, if I start a stream from TVguide, that is already being recoded, it's like it start a new stream, so I cannot jump back to the beginning.2. SO on my "Emby for Android TV" app, I instead have to go "Recorded TV", and from here I can actually jump into the currently recording stream, both starting from beginning, and also continue to watch the whole movie as it's being recoded. THIS WORKS OK 3. BUG/ISSUE - However, the scenario described in #2 above, does not seem to work on "Emby for Android" and "Emby Theater - Desktop edition". In both of these apps, when I want to watch a currenty ongoing recording from the "Recorded TV", it's acting wierd. I think it jumps to the live TV point, and I'm not able to jump back a start from beginning of the movie.
Luke 42244 Posted June 18, 2019 Posted June 18, 2019 @@simonselmer thanks for the feedback. We are looking into improving this. Thanks. 1
aja07 20 Posted August 13, 2019 Posted August 13, 2019 Tried to start playing a show whilst still recording on Emby Theatre W10 and all I got was the spinning circles. Only way out was to exit out of Emby Theatre and restart. Tried 3 times, same result so gave up. Will try again tomorrow and test with Android TV as well.
brettuk 1 Posted August 15, 2019 Posted August 15, 2019 I've got the same issue - if you wait long enough it will eventually work - but for some reason its transcoding despite the fact live tv works without transcoding on Emby Theatre. It's a lot quicker to start on the web version, but it's still transcoding. Why can't it use native MPEG2?
Luke 42244 Posted August 30, 2019 Posted August 30, 2019 I've got the same issue - if you wait long enough it will eventually work - but for some reason its transcoding despite the fact live tv works without transcoding on Emby Theatre. It's a lot quicker to start on the web version, but it's still transcoding. Why can't it use native MPEG2? hi @@brettuk, web browsers do not support mpeg2. Does that answer your question?
sundevil67 30 Posted September 8, 2019 Posted September 8, 2019 I finally got Live TV working, and my main reason for using the DVR/recording feature is to be able to watch baseball on a delay. It looks like I can't fast-forward at all when a recording is in progress, which is really important for baseball. Is this expected behavior? Must I stop the recording to be able to do this? I keep accidentally seeing the live feed, which of course instantly ruins the whole thing. Is there any way to watch/scrub while recording? I'm just trying to figure out if this is something that's supposed to work, but for some reason doesn't with my setup. Is this one of those things that'd be better when connected with an external media player application? Thanks.
clollar 9 Posted September 9, 2019 Posted September 9, 2019 (edited) Seems this happens every single football season. Due to the nature of sports users often want to start in progress recordings. Yet every year I run into this issue. Is there some legacy issue I don't know about? What's the problem? When will it be fixed? Anyone know if Plex has the same issue. Here's my issue. I try to start an in progress recording (Steelers vs Pats in this example) and it crashes the app. Very frustrating for sports fans guys, can we figure this out. Server log attached. Edited September 9, 2019 by clollar
clollar 9 Posted September 9, 2019 Posted September 9, 2019 Oh this might help. On the Android TV app (Shield) there is an option when you select the "on now", basically go to the actual channel the recording is currently on, there's a start from beginning option. That seemed to work. However there's no "resume from" option once you back out and reenter. Also I have not seen this option on my Android phone or ET.
simonselmer 27 Posted September 9, 2019 Author Posted September 9, 2019 Which client are you using? I was having some of the same issue on my Shield TV. In another thread on that specific issue of not being to skip forward or it would take a long time to skip forward in an ongoing recording, it improved my experience to update mu Shield to a beta-version. There was a link to how to get that in another thread. It has improved my experience, BUT it could still be better. The issue still seems to be when the recording is ongoing, because once the recording has stopped, it's much more fluent as I recall. If you do not have the Shield as client, then my suggestion is no good to you I finally got Live TV working, and my main reason for using the DVR/recording feature is to be able to watch baseball on a delay. It looks like I can't fast-forward at all when a recording is in progress, which is really important for baseball. Is this expected behavior? Must I stop the recording to be able to do this? I keep accidentally seeing the live feed, which of course instantly ruins the whole thing. Is there any way to watch/scrub while recording? I'm just trying to figure out if this is something that's supposed to work, but for some reason doesn't with my setup. Is this one of those things that'd be better when connected with an external media player application? Thanks.
sundevil67 30 Posted September 9, 2019 Posted September 9, 2019 Using the web client (server running on Mac OS)
Luke 42244 Posted September 11, 2019 Posted September 11, 2019 Can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
brettuk 1 Posted September 19, 2019 Posted September 19, 2019 hi @@brettuk, web browsers do not support mpeg2. Does that answer your question? Sorry I didn't see you replied. I'm having this issue with emby theatre, its transcoding even though live TV and recorded TV is direct play - it takes ages to start watching a recording in progress too, taking up to a couple of minutes.
Luke 42244 Posted September 20, 2019 Posted September 20, 2019 Sorry I didn't see you replied. I'm having this issue with emby theatre, its transcoding even though live TV and recorded TV is direct play - it takes ages to start watching a recording in progress too, taking up to a couple of minutes. @@brettuk can we please look at an example? thanks !
brettuk 1 Posted September 20, 2019 Posted September 20, 2019 @@brettuk can we please look at an example? thanks ! This is me watching it live directly from the channel - note it's direct play and instant to start: If I watch a previously recorded episode, it is also directplay and instant to start: However watching a recording in progress sits at this screen for a min or so: And then will only be transcoded - it also mean you can't fast forward as the slider is slowly expanding (it has recorded more than 12 seconds when I took this screenshot): Can't see a way to upload logs, so put them on drive and shared: https://drive.google.com/drive/folders/12r5sqRJjniX4Ek1EsWBEkzb1ysvYhvWb?usp=sharing
brettuk 1 Posted October 28, 2019 Posted October 28, 2019 @@brettuk can we please look at an example? thanks ! Any update on this? Thanks
Guest asrequested Posted October 28, 2019 Posted October 28, 2019 This is me watching it live directly from the channel - note it's direct play and instant to start: If I watch a previously recorded episode, it is also directplay and instant to start: However watching a recording in progress sits at this screen for a min or so: And then will only be transcoded - it also mean you can't fast forward as the slider is slowly expanding (it has recorded more than 12 seconds when I took this screenshot): Can't see a way to upload logs, so put them on drive and shared: https://drive.google.com/drive/folders/12r5sqRJjniX4Ek1EsWBEkzb1ysvYhvWb?usp=sharing Probably this https://emby.media/community/index.php?/topic/78315-the-server-is-transcoding-an-in-progress-recording/&do=findComment&comment=795675
brettuk 1 Posted October 28, 2019 Posted October 28, 2019 Probably this https://emby.media/community/index.php?/topic/78315-the-server-is-transcoding-an-in-progress-recording/&do=findComment&comment=795675 Yeah looks like the same issue - it's very frustrating.
Luke 42244 Posted November 3, 2019 Posted November 3, 2019 Are you able to play in-progress recordings using the Emby web app?
brettuk 1 Posted November 4, 2019 Posted November 4, 2019 (edited) Are you able to play in-progress recordings using the Emby web app? For me that's not working at all. Not quite true, Chrome web isn't working at all (even for already recorded programmes), Edge is, it plays currently recording TV audio but shows a black screen. Interestingly, due to unimportant reasons I've been using the Emby Fire TV app more over the past week, and that handles in progress recordings perfectly. If I select a TV programme from the guide that is recording, I have the option to watch from the start and it starts playing within seconds. Edited November 4, 2019 by brettuk
Luke 42244 Posted November 17, 2019 Posted November 17, 2019 We're looking into it. Thanks for reporting.
sihy 0 Posted November 23, 2019 Posted November 23, 2019 (edited) I have the same issue as @brettuk using an RPi4 emby server (docker container) streaming to Apple TV 4k emby app. Playing an mpegts container with mpeg2 video and aac audio works fine as a Live TV channel or as a completed recording (i.e. no transcoding). Playing an in progress recording causes emby to transcode the video using libx264 and copy thru the aac audio. This happens for both DVBT and DVBT2 streams i.e. mpeg2 and h264. I have some raw video streams that tvheadend transcodes into mpeg2/aac/ts on the same Rpi4. The RPi4 can do this quite comfortably and feed it to emby for recording/playback, but when emby also transcodes it again it hasn't got quite enough grunt for two simultaneous transcodes so the video stutters a little. Cheers, Simon Edited November 24, 2019 by sihy
Red5ive 30 Posted December 5, 2019 Posted December 5, 2019 Just adding my 'me to' to this thread. Using Emby theater on the same pc as the recordings take place, playing of currently recorded shows don't start. Is this also related to the issue where if you pause a live tv show and then try and fast forward to the end it will hang for 30+ seconds before playing again?
Luke 42244 Posted December 29, 2019 Posted December 29, 2019 We're looking into this. Thanks for reporting.
DamnedUndies 17 Posted December 30, 2019 Posted December 30, 2019 I've got a similar issue when watching a recording of an in-progress live TV recording. The quality is horrendous, as I've noticed, while watching NFL games. The pixelating is so bad that the ball disappears once it leaves the QB's hand when passing, and I need to wait until a receiver catches it to figure out where it went. As a paying lifetime Emby Premiere member, this is very disappointing. If I stop the recording and go to the live TV feed, the picture is awesome. Not sure if the issue is due to: - an underpowered server that can't walk and chew gum at the same time - network overload with both the HDHR box and server recording/playing at the same time - some devious software-related Emby server/client issue Here's my configuration: HDHR Extend. I'm watching using Roku+ stick connected via 100Mb+ 5GHz WiFi to the local server: Unfortunately I don't have the server log but will reproduce when the Patriots play Tennessee next Saturday
ebr 16337 Posted December 31, 2019 Posted December 31, 2019 I've got a similar issue when watching a recording of an in-progress live TV recording. The quality is horrendous, as I've noticed, while watching NFL games. The pixelating is so bad that the ball disappears once it leaves the QB's hand when passing, and I need to wait until a receiver catches it to figure out where it went. As a paying lifetime Emby Premiere member, this is very disappointing. If I stop the recording and go to the live TV feed, the picture is awesome. Not sure if the issue is due to: - an underpowered server that can't walk and chew gum at the same time - network overload with both the HDHR box and server recording/playing at the same time - some devious software-related Emby server/client issue Here's my configuration: HDHR Extend. I'm watching using Roku+ stick connected via 100Mb+ 5GHz WiFi to the local server: Unfortunately I don't have the server log but will reproduce when the Patriots play Tennessee next Saturday Hi. Please post a transcoding log from the in-progress playback. I suspect that CPU cannot keep up but we need to take a look.
