bomberjim 2 Posted May 19, 2014 Posted May 19, 2014 Early last week I upgraded from MB 2.6.2 and although things are working quite well, I think I found a bug (or at least a conflict) between Automatic Box Sets and Coverart. Additionally there also appears to be an update problem with Trailers. 1. When I installed Automatic Box Sets, Collections were created as expected. However, the "cover" that was created did not say "Boxset", it said "H264" or "MPEG", depending on what type of video was in the collection. If I go into the collection using Media Browser Classic, and do a manual refresh (cntrl R) the boxset coverart changes to "Boxset", but all the movies, backdrops etc. disappear from the collection. I can go back into MB server and re-add the movies to the collection, but then the coverart returns to "H264". In other words, you can't use Cntrl R to refresh a collection if Coverart is installed. 2. Trailers (the plug-in) doesn't appear to be receiving updates. I'm talking about streaming trailers, not local trailers. The streaming trailers haven't updated since I installed the plug-in, and the latest movie trailer is listed as added on 8 May.
ebr 16305 Posted May 19, 2014 Posted May 19, 2014 For issue 1 - go into "Specific Covers" in the profile page in Cover Art configuration and map "BoxSet" to "Box Set". This will give you the box set labelled cover. The refresh thing doesn't really have anything to do with CoverArt I don't think.
bomberjim 2 Posted May 19, 2014 Author Posted May 19, 2014 Thanks ebr, No the Trailers thing doesn't have anything to do with CoverArt, it's just a problem I think exists with the plug-in. Seems like it might be a server issue since I believe it was happening with MB 2.6.2 as well. Seems like it started when the old server was taken down and has continued with MB3. Is there somewhere else I should post about this?
bomberjim 2 Posted May 19, 2014 Author Posted May 19, 2014 Sorry to bother you again, but I can't find what you're referring to. I assume you mean under Plugins I select: CoverArt Default Specific Covers tab Create Specific Selection and then I'm stuck. There is no "Box Set" choice under either drop down list.
ebr 16305 Posted May 19, 2014 Posted May 19, 2014 I already have the mapping setup but here it is in the drop down...
bomberjim 2 Posted May 19, 2014 Author Posted May 19, 2014 Got it thanks. I was looking for Box Set - with a space.
