athurlow 0 Posted May 14, 2019 Posted May 14, 2019 I’ve set up the Emby server on my Mac mini but can’t figure a way to play any plugins from the plugin folder. I’ve tried using a Roku and Apple TV but there’s no way to play plugins they only show in plugins folder. It looks like I need move the plugins to the library but how?
chef 3811 Posted May 14, 2019 Posted May 14, 2019 (edited) Hi athurlow, Plugins are not ment to be played as media. They are libraries for the server to add functionality. For instance, a subtitle plugin will allow the server to gather appropriate subtitles for your media to display while you are watching it. Certain plugins may add "channels" to your home screen for things like trailers, others may add scheduled tasks to the server. Certain plugins are only available for premier users, but most are available to use freely. I hope this helps. Edited May 14, 2019 by chef
athurlow 0 Posted May 14, 2019 Author Posted May 14, 2019 I’ve got all the plugins that came with the server download under my plugins I’m trying to use podcasts and a music one but they are nowhere’s to be found on the Apple TV or Roku.
chef 3811 Posted May 14, 2019 Posted May 14, 2019 (edited) I’ve got all the plugins that came with the server download under my plugins I’m trying to use podcasts and a music one but they are nowhere’s to be found on the Apple TV or Roku.The music plugins are for gathering metadata for your music library. Artist, album and song info. This is gathered during a library refresh under scheduled tasks. The podcast plugin is a channel plugin (from what I gather). Someone else may have to chime in, but it should create a library on your home page called "podcasts" where you would find a list of podcasts you have added from the plugin configuration. All plugin configurations (if they have configurations, because some do not need it) can be accessed by right clicking the plugin image in your catalog and selecting "settings". Edited May 14, 2019 by chef
athurlow 0 Posted May 16, 2019 Author Posted May 16, 2019 I’ve added a few podcasts to the podcast plugin, but I’m unable to find a way to play them. There not showing up on the Roku or Apple TV.
chef 3811 Posted May 16, 2019 Posted May 16, 2019 (edited) So on the home screen under "My Media" you should see "Movies", "TV Shows", etc. You should see "Podcasts" listed there. Is that channel listed in the web browser client? Edited May 16, 2019 by chef
athurlow 0 Posted May 16, 2019 Author Posted May 16, 2019 The only thing I have on my home screen is my media and under that a folder called playlists. I don’t have movies or tv shows. Are there any videos to help set it up.
chef 3811 Posted May 16, 2019 Posted May 16, 2019 After you have finished the settings in the plugin configuration, go to scheduled tasks and press the "refresh internet channels". See if that helps
athurlow 0 Posted May 17, 2019 Author Posted May 17, 2019 I tried that, no luck. I’m sure it’s something simple and I can’t figure it out.
chef 3811 Posted May 17, 2019 Posted May 17, 2019 Hey @@athurlow are you an emby supporter? Did you purchase a premiere package for emby? The podcast plugin will only work for premiere members.
athurlow 0 Posted May 21, 2019 Author Posted May 21, 2019 (edited) I’ve paid for a month of Emby premiere and still no plugins. I see the plugins in the dashboard under my plugins. When I use the Roku or Apple TV I have the home screen of playlists and live tv but no plugins How do I move the my plugins folder to the home screen. Edited May 21, 2019 by athurlow
athurlow 0 Posted May 21, 2019 Author Posted May 21, 2019 Cinema mode, trailers, podcasts and all the ones that came in my plugins.
Luke 42255 Posted May 21, 2019 Posted May 21, 2019 Did you configure the podcasts plugin with podcast feeds?
Luke 42255 Posted May 21, 2019 Posted May 21, 2019 Did you check the access settings for your emby users to make sure they are granted access to the plugin content?
athurlow 0 Posted May 21, 2019 Author Posted May 21, 2019 The only thing I find under access settings under users is library access, I don’t have anything else.
Luke 42255 Posted May 23, 2019 Posted May 23, 2019 Can you please attach the emby server log? You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
