all4dom 101 Posted May 14, 2019 Posted May 14, 2019 For some strange reason, the numbers appear outside of the box for kids tv. It does not appear that way in any of my other folders. This is only on my roku ultra & premier. I do not have this problem on my fire tv. Also, the content for this folder is considered mixed. Im not sure if it happened after a server update or roku update. Thanks Dom Log1.txt Log2.txt
Happy2Play 9811 Posted May 14, 2019 Posted May 14, 2019 It would appear you are on the Roku official release (Roku SG 3.0.155). I will have to check mine Roku in a bit. But the number count would appear in the right location for a landscape image and you have poster images.
ebr 16335 Posted May 14, 2019 Posted May 14, 2019 Yes, when dealing with a folder view, there is no way for us to accurately predict the size and shape of the images and the Roku vertical grid must show all items at the same size. So, we have to choose a size that we're sure will fit your image.
all4dom 101 Posted May 14, 2019 Author Posted May 14, 2019 So how can I fix this. I think the cover images are what ever was recommended. All my other folders are ok & now displaying that issue. Duny thing is this just happened not to long ago. Any recommendations?
Luke 42242 Posted May 14, 2019 Posted May 14, 2019 The best thing to do would be to use a library with content type TV. Mixed is a free for all, and while the other apps can generally react dynamically to the content, it's much more difficult to do on the Roku.
