shayyqz 0 Posted May 13, 2019 Posted May 13, 2019 5 seconds ago Hi all I have samsung tv model Q7F65 (qled tv ) and i want to watch movies with headphones Usually over the years in previous TVs of Samsung I was connecting headphones to the Headphone jack in Samsung TV And now in this model of tv does not have Headphone jack connection i was allready try to connect - optical to analog adapters but But the sound is weak and not qualityThe volume can not be adjustedAnd it requires every time to re-connect the equipment and spend precious time. THE TV ALSO SUPPORT BLUETOOTH CONNECTION But I searched and searched and did not find any Samsung Bluetooth headphones designed for movies It's important to me that there be quality sound also volume adjustment and good battery If anyone has suggestions or another solution How can I hear with headphones on this TV I would be appreciate for your help thanks
holdestmade 11 Posted May 16, 2019 Posted May 16, 2019 (edited) I have the same TV and use some Sennheiser bluetooth headphones, they are great quality and sound great for music and movies, battery lasts for weeks, but I use them maybe only 1-2 times a week for a few hours Other alternative is a bluetooth adapter to plug you headphones in and connect to TV with bluetooth but not sure of the quality, there's lots on Amazon Edited May 16, 2019 by holdestmade 2
shayyqz 0 Posted May 16, 2019 Author Posted May 16, 2019 (edited) Hi holdestmade thanks for your reply can you please send the exact model of your Sennheiser bluetooth headphones that you have ? and about the other alternative Can recommend for good bluetooth adapter that you see on amazon \ ebay Which can be connected to the power supply, to control the volume level , and also have audio jack phone , And excellent sound quality ? thanks Edited May 16, 2019 by shayyqz
holdestmade 11 Posted May 17, 2019 Posted May 17, 2019 Hi, These are my headphones I use most of the time: https://www.amazon.c...sc=1&th=1&psc=1 I also have these and they are just about as good and a lot cheaper: https://www.amazon.c...sc=1&th=1&psc=1 A Bluetooth adapter is here, but not sure of the quality as I have not used them. Also, they are battery powered so you can plug you headphones in: https://www.amazon.c...gateway&sr=8-38
