archangelz 13 Posted May 13, 2019 Posted May 13, 2019 (edited) Running Emby clients on my Nvidia shield TV and the audio output is really really low on Emby specifically on standard HDMI to my TV speakers. I have to crank my TV to almost max volume to hear anything and it's a problem when I have to switch inputs on my TV. Cable box to the same TV nor my playstation have this issue. This is not a problem on Netflix or Prime Video on the same device also Kodi w/ Emby works fine as well. Files are being directly played back with no transcoding from the server. Different videos have different audio playback levels, would be nice to normalize them so there isn't a huge variation between playback of different files. I couldn't find anything on the Nvidia shield settings itself or Emby Android app settings that would help with this. Did I miss anything? Edited May 13, 2019 by archangelz
Luke 42246 Posted May 13, 2019 Posted May 13, 2019 Hi there, let's look at how it is playing. Please attach the information requested in how to report a media playback issue. thanks !
ebr 16338 Posted May 13, 2019 Posted May 13, 2019 Hi. Also, make sure that the device's volume control is all the way up by swiping up on the slider on the Shield remote. Thanks.
CBers 7554 Posted May 13, 2019 Posted May 13, 2019 Do you have the "Downmix to Stereo" option enabled within the Emby app?
ebr 16338 Posted May 13, 2019 Posted May 13, 2019 Do you have the "Downmix to Stereo" option enabled within the Emby app? He mentioned using his TV speakers, so it is likely downmixing even in "auto".
archangelz 13 Posted May 16, 2019 Author Posted May 16, 2019 (edited) Logs attached. Yes I'm set to auto. Playing Chernobyl first episode Log.txt Edited May 16, 2019 by archangelz
Jdiesel 1437 Posted May 16, 2019 Posted May 16, 2019 I started having this exact problem a few months ago. It started out of nowhere with no equipment changes. Happens when downmixing to stereo. I reported it but didn't get much luck getting it looked at. In the end I bought a soundbar that I could pass DD and DTS too, not ideal but it solves the low volume with Emby issue.
