jxb1234 9 Posted December 29, 2019 Posted December 29, 2019 ~Cheers- I've given it max threads. Now using 15% CPU (8 cores, docker). I'll mess with it another day.
jxb1234 9 Posted December 30, 2019 Posted December 30, 2019 (edited) Right- After conversion completed, I got no android notification that it was downloading. The "my downloads -> manage" screen sat on downloading 0%, then after a while it changed to "downloaded". So there is an issue there when media is converted then downloaded. It would be useful if the movie screen's "downloading" icon showed "converting xx%", and then "downloading xx%" when these operations are in progress. The android notification is not reliable (for me, at least). Edited December 30, 2019 by jxb1234
Luke 42244 Posted December 30, 2019 Posted December 30, 2019 Yes we will be improving the in-app progress reporting. Thanks for the feedback.
rechigo 367 Posted January 7, 2020 Posted January 7, 2020 ~Cheers- I've given it max threads. Now using 15% CPU (8 cores, docker). I'll mess with it another day.You should be able to get it to use more. There are additional settings specific to conversions in the dashboard. Go to dashboard -> conversions -> settings -> enable full speed conversion. Sent from my SM-G973U using Tapatalk
