jbirmingham40 9 Posted May 12, 2019 Posted May 12, 2019 My IPTV provider occasionally has issues with certain channels and returns a 403 for multiple hours. When this happens things get ugly with Emby. To start with it Emby logs the following message rapidly overwhelming the disk. 2019-05-12 14:31:21.505 Info App: Opening SharedHttpStream Live stream from http://localhost:8090/M5acRagHhE/10545 2019-05-12 14:31:21.505 Error App: Error copying live stream, will keep trying. *** Error Report *** Version: 4.2.0.5 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-rpm_{version}_x86_64.rpm Operating system: Unix 3.10.0.957 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 6 Program data path: /var/lib/emby Application directory: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Cancelling connection to http://localhost:8090/M5acRagHhE/10545 due to a previous timeout. at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.LiveTV.TunerHosts.SharedHttpStream.OpenStream(IDisposable connectionContext, MediaSourceInfo mediaSource, String url, MediaProtocol protocol, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.SharedHttpStream.<>c__DisplayClass7_0.<<StartStreaming>b__0>d.MoveNext() Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2019-05-12 14:31:21.505 Info App: Opening SharedHttpStream Live stream from http://localhost:8090/M5acRagHhE/10545 2019-05-12 14:31:21.506 Error App: Error copying live stream, will keep trying. *** Error Report *** Version: 4.2.0.5 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-rpm_{version}_x86_64.rpm Operating system: Unix 3.10.0.957 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 6 Program data path: /var/lib/emby Application directory: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Cancelling connection to http://localhost:8090/M5acRagHhE/10545 due to a previous timeout. at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.LiveTV.TunerHosts.SharedHttpStream.OpenStream(IDisposable connectionContext, MediaSourceInfo mediaSource, String url, MediaProtocol protocol, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.SharedHttpStream.<>c__DisplayClass7_0.<<StartStreaming>b__0>d.MoveNext() Source: Emby.Server.Implementations TargetSite: Void MoveNext() It generated a log that is 637MB in size in only two hours and fifteen minutes. In fact it was logging so fast that it could not actually write the logs to disk at the same rate it was generating them. Logging was almost two hours behind when I restarted emby. I checked and debug logging is not enabled. I am thrilled that Emby is retrying but wish it wasn't so verbose about it. It is possible to replace the errors shown above with a less verbose summary log message every minute or so? My logs indicate t was as a result of somebody trying to watch a live tv show on my Game room fire tv stick. You can see in the dashboard they tried at 14:13, again at 14:16, and then gave up at 14:21. Local is playing Sportsnet West CA HD on Game room fire tv stick 5/12/2019, 2:14:32 pm Local is playing Sportsnet West CA HD on Game room fire tv stick 5/12/2019, 2:16:23 pm Local has finished playing Sportsnet West CA HD on Game room fire tv stick 5/12/2019, 2:21:32 pm If that is true then it isn't clear why Emby kept retrying for so long. As you can see from the first set of logs above emby was still logging these error messages at 14:31 and I presume far later than that as the logs were two hours behind. Seems like an issue where it gets stuck in a retry loop. The logs from the beginning of the session are below. Please let me know if you need any more. Can't send the full log since it is more than half a GB. 2019-05-12 14:13:11.100 Info HttpServer: HTTP GET http://192.168.0.1:8096/emby/videos/32355/live.m3u8?DeviceId=733e081ee7c1db3&MediaSourceId=09a6a50a334a19d9d837f33daee8dc94&PlaySessionId=d0450a013ae44b1cbd90541ebf1a5a1b&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_09a6a50a334a19d9d837f33daee8dc94&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=ac3,eac3,aac,mp3&VideoBitrate=79877375&AudioBitrate=122625&AudioStreamIndex=-1&SubtitleMethod=Encode&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&hevc-profile=Main,Main10&ac3-audiochannels=8&eac3-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8. X-Real-IP=192.168.0.249, Host=192.168.0.1, X-Forwarded-For=192.168.0.249, Connection=upgrade, User-Agent=Emby/1.6.94a (Linux;Android 7.1.2) AmznExoPlayerLib/2.9.0/Emby, Accept-Encoding=gzip 2019-05-12 14:13:11.138 Info HttpServer: HTTP Response 200 to 192.168.0.249. Time: 38ms. http://192.168.0.1:8096/emby/videos/32355/live.m3u8?DeviceId=733e081ee7c1db3&MediaSourceId=09a6a50a334a19d9d837f33daee8dc94&PlaySessionId=d0450a013ae44b1cbd90541ebf1a5a1b&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_09a6a50a334a19d9d837f33daee8dc94&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=ac3,eac3,aac,mp3&VideoBitrate=79877375&AudioBitrate=122625&AudioStreamIndex=-1&SubtitleMethod=Encode&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&hevc-profile=Main,Main10&ac3-audiochannels=8&eac3-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8 2019-05-12 14:13:11.810 Info HttpServer: HTTP POST http://192.168.0.1:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 7.1.2; AFTMM Build/NS6263) 2019-05-12 14:13:11.810 Info HttpServer: HTTP Response 204 to 192.168.0.249. Time: 1ms. http://192.168.0.1:8096/emby/Sessions/Playing/Progress 2019-05-12 14:13:13.067 Info HttpServer: HTTP POST http://192.168.0.1:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 7.1.2; AFTMM Build/NS6263) 2019-05-12 14:13:13.068 Info HttpServer: HTTP Response 204 to 192.168.0.105. Time: 1ms. http://192.168.0.1:8096/emby/Sessions/Playing/Progress 2019-05-12 14:13:14.899 Info HttpServer: HTTP GET http://192.168.0.1:8096/emby/videos/32355/live.m3u8?DeviceId=733e081ee7c1db3&MediaSourceId=09a6a50a334a19d9d837f33daee8dc94&PlaySessionId=d0450a013ae44b1cbd90541ebf1a5a1b&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_09a6a50a334a19d9d837f33daee8dc94&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=ac3,eac3,aac,mp3&VideoBitrate=79877375&AudioBitrate=122625&AudioStreamIndex=-1&SubtitleMethod=Encode&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&hevc-profile=Main,Main10&ac3-audiochannels=8&eac3-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8. X-Real-IP=192.168.0.249, Host=192.168.0.1, X-Forwarded-For=192.168.0.249, Connection=upgrade, User-Agent=Emby/1.6.94a (Linux;Android 7.1.2) AmznExoPlayerLib/2.9.0/Emby, Accept-Encoding=gzip 2019-05-12 14:13:14.938 Info HttpServer: HTTP Response 200 to 192.168.0.249. Time: 39ms. http://192.168.0.1:8096/emby/videos/32355/live.m3u8?DeviceId=733e081ee7c1db3&MediaSourceId=09a6a50a334a19d9d837f33daee8dc94&PlaySessionId=d0450a013ae44b1cbd90541ebf1a5a1b&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_09a6a50a334a19d9d837f33daee8dc94&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=ac3,eac3,aac,mp3&VideoBitrate=79877375&AudioBitrate=122625&AudioStreamIndex=-1&SubtitleMethod=Encode&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&hevc-profile=Main,Main10&ac3-audiochannels=8&eac3-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8 2019-05-12 14:13:16.678 Info App: Opening SharedHttpStream Live stream from http://localhost:8090/M5acRagHhE/10545 2019-05-12 14:13:16.678 Info HttpClient: GET http://localhost:8090/M5acRagHhE/10545 2019-05-12 14:13:16.830 Info HttpServer: HTTP GET http://192.168.0.1:8096/emby/videos/32355/master.m3u8?DeviceId=733e081ee7c1db3&MediaSourceId=09a6a50a334a19d9d837f33daee8dc94&PlaySessionId=d0450a013ae44b1cbd90541ebf1a5a1b&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_09a6a50a334a19d9d837f33daee8dc94&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=ac3,eac3,aac,mp3&VideoBitrate=79877375&AudioBitrate=122625&AudioStreamIndex=-1&SubtitleMethod=Encode&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&hevc-profile=Main,Main10&ac3-audiochannels=8&eac3-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8. X-Real-IP=192.168.0.249, Host=192.168.0.1, X-Forwarded-For=192.168.0.249, Connection=upgrade, User-Agent=Emby/1.6.94a (Linux;Android 7.1.2) AmznExoPlayerLib/2.9.0/Emby, Accept-Encoding=gzip 2019-05-12 14:13:16.830 Info HttpServer: HTTP Response 200 to 192.168.0.249. Time: 1ms. http://192.168.0.1:8096/emby/videos/32355/master.m3u8?DeviceId=733e081ee7c1db3&MediaSourceId=09a6a50a334a19d9d837f33daee8dc94&PlaySessionId=d0450a013ae44b1cbd90541ebf1a5a1b&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_09a6a50a334a19d9d837f33daee8dc94&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=ac3,eac3,aac,mp3&VideoBitrate=79877375&AudioBitrate=122625&AudioStreamIndex=-1&SubtitleMethod=Encode&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&hevc-profile=Main,Main10&ac3-audiochannels=8&eac3-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8 2019-05-12 14:13:16.854 Info HttpServer: HTTP GET http://192.168.0.1:8096/emby/videos/32355/live.m3u8?DeviceId=733e081ee7c1db3&MediaSourceId=09a6a50a334a19d9d837f33daee8dc94&PlaySessionId=d0450a013ae44b1cbd90541ebf1a5a1b&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_09a6a50a334a19d9d837f33daee8dc94&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=ac3,eac3,aac,mp3&VideoBitrate=79877375&AudioBitrate=122625&AudioStreamIndex=-1&SubtitleMethod=Encode&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&hevc-profile=Main,Main10&ac3-audiochannels=8&eac3-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8. X-Real-IP=192.168.0.249, Host=192.168.0.1, X-Forwarded-For=192.168.0.249, Connection=upgrade, User-Agent=Emby/1.6.94a (Linux;Android 7.1.2) AmznExoPlayerLib/2.9.0/Emby, Accept-Encoding=gzip 2019-05-12 14:13:16.893 Info HttpServer: HTTP Response 200 to 192.168.0.249. Time: 39ms. http://192.168.0.1:8096/emby/videos/32355/live.m3u8?DeviceId=733e081ee7c1db3&MediaSourceId=09a6a50a334a19d9d837f33daee8dc94&PlaySessionId=d0450a013ae44b1cbd90541ebf1a5a1b&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_09a6a50a334a19d9d837f33daee8dc94&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=ac3,eac3,aac,mp3&VideoBitrate=79877375&AudioBitrate=122625&AudioStreamIndex=-1&SubtitleMethod=Encode&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&hevc-profile=Main,Main10&ac3-audiochannels=8&eac3-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8 2019-05-12 14:13:17.701 Error App: Error copying live stream, will keep trying. *** Error Report *** Version: 4.2.0.5 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-rpm_{version}_x86_64.rpm Operating system: Unix 3.10.0.957 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 6 Program data path: /var/lib/emby Application directory: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Forbidden at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.LiveTV.TunerHosts.SharedHttpStream.OpenStream(IDisposable connectionContext, MediaSourceInfo mediaSource, String url, MediaProtocol protocol, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.SharedHttpStream.<>c__DisplayClass7_0.<<StartStreaming>b__0>d.MoveNext() Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2019-05-12 14:13:17.701 Info App: Opening SharedHttpStream Live stream from http://localhost:8090/M5acRagHhE/10545 2019-05-12 14:13:17.701 Info HttpClient: GET http://localhost:8090/M5acRagHhE/10545 2019-05-12 14:13:17.999 Info HttpClient: Http response 403 from http://localhost:8090/M5acRagHhE/10545 after 298ms. HeadersServer=nginx, Date=Sun, 12 May 2019 19:12:45 GMT, Connection=close, Access-Control-Allow-Origin=* 2019-05-12 14:13:18.000 Error App: Error copying live stream, will keep trying. *** Error Report *** Version: 4.2.0.5 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-rpm_{version}_x86_64.rpm Operating system: Unix 3.10.0.957 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 6 Program data path: /var/lib/emby Application directory: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Forbidden at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.LiveTV.TunerHosts.SharedHttpStream.OpenStream(IDisposable connectionContext, MediaSourceInfo mediaSource, String url, MediaProtocol protocol, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.SharedHttpStream.<>c__DisplayClass7_0.<<StartStreaming>b__0>d.MoveNext() Source: Emby.Server.Implementations at Emby.LiveTV.TunerHosts.SharedHttpStream.<>c__DisplayClass7_0.<<StartStreaming>b__0>d.MoveNext() Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2019-05-12 14:13:18.000 Info App: Opening SharedHttpStream Live stream from http://localhost:8090/M5acRagHhE/10545 2019-05-12 14:13:18.000 Info HttpClient: GET http://localhost:8090/M5acRagHhE/10545 2019-05-12 14:13:18.461 Info HttpClient: Http response 403 from http://localhost:8090/M5acRagHhE/10545 after 461ms. HeadersServer=nginx, Date=Sun, 12 May 2019 19:12:46 GMT, Connection=close, Access-Control-Allow-Origin=* 2019-05-12 14:13:18.462 Error App: Error copying live stream, will keep trying. *** Error Report *** Version: 4.2.0.5 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-rpm_{version}_x86_64.rpm Operating system: Unix 3.10.0.957 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 6 Program data path: /var/lib/emby Application directory: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Forbidden at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.LiveTV.TunerHosts.SharedHttpStream.OpenStream(IDisposable connectionContext, MediaSourceInfo mediaSource, String url, MediaProtocol protocol, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.SharedHttpStream.<>c__DisplayClass7_0.<<StartStreaming>b__0>d.MoveNext() Source: Emby.Server.Implementations TargetSite: Void MoveNext()
jbirmingham40 9 Posted May 13, 2019 Author Posted May 13, 2019 FWIW, I discovered that this wasn’t caused by a user watching a new program. Rather it was caused by a runaway live tv session. We started watching this channel are 11pm last night. It Seems to have played continuously all night. Unclear why this error started at 14:13 today. I am guessing this is when the provider started having issues. Based on this I suppose I can understand why Emby kept trying to play the live stream forever (i.e. it thought I was still watching it). Would be nice if it would give up after a certain amount of time. It isn’t likely that a user is going to sit there for hours waiting for the live program to resume once the provider is back up. Then again maybe there is a use case for that. Either way would be great if there was a configurable retry limit for live tv. The less aggressive logging feels like a much more critical feature. I can live with run away live tv sessions as eventually I would discover them. I cannot live with the entire server becoming overwhelmed because of the aggressive logging when the provider goes down.
Luke 42246 Posted May 13, 2019 Posted May 13, 2019 Hi, yes we can reduce the logging when this happens. Thanks.
