saajan4u 79 Posted May 19, 2014 Posted May 19, 2014 I only just had some time to mess around with this. and I think it is a brilliant touch to show off. it works a treat with MBT and i love it but i havent moved my living room HTPC to MBT yet as it doesnt tick all the boxes for me just yet ! i.e live tv support plus controlling it with remote i'm not happy with it yet. I have the movie theme song/video pluggin installed on the mbc but it doesnt play anything for some reason. also can somebody tell me how to buy the full version of it? do I have to donate 1st? can I not just buy the plugin? i know I ask alot of question here.. your help and support is much appreciated.
Yogi 367 Posted May 19, 2014 Posted May 19, 2014 Hi saajan4u, 1. You obviously have the server plugin installed and by the sounds of it also the mbc plugin installed.Now you need to go to the MBC configurator in the start menu find mediabrowser ad cliick on mb classic configuraor and then go to plugins.Highlight the ThemeVideo backdrops and the click on the configure button and go from there. If you are supporter and already have a mb3 key,all you need to do now is purchase the plugins required. I suggest you also check out the video backdrops as they also brilliant and add to the mb experience so much more.
saajan4u 79 Posted May 19, 2014 Author Posted May 19, 2014 ah that would explain why.. thank you.. very much for taking the time to show me this much appreciated
saajan4u 79 Posted May 19, 2014 Author Posted May 19, 2014 I just got the supporter key. now how do i actually buy an individual item?
Yogi 367 Posted May 19, 2014 Posted May 19, 2014 (edited) I just got the supporter key. now how do i actually buy an individual item? open the server/web client,click on plugins and view the catalogue,pick the plugin you want to purchase it will open up and scroll down and you will see the below screenshot.click on paypal and go from there. Edited May 19, 2014 by Yogi 1
saajan4u 79 Posted May 19, 2014 Author Posted May 19, 2014 for some reason i dont get that option as you do and as you can see i've just become a supporter for mb3 may be i just have to give it sometime
ebr 16344 Posted May 19, 2014 Posted May 19, 2014 Look at Yogi's screen shot again. You are in the wrong place. You need to go to the Plug-in catalog and find the plug-in you are trying to register. 1
saajan4u 79 Posted May 19, 2014 Author Posted May 19, 2014 i had to remove it then went to the cataloge and it appeared.. thank you guys.. you guys are awsome
saajan4u 79 Posted May 19, 2014 Author Posted May 19, 2014 i hope they'd just did a purchase pack.. basically one price for the whole lot rather than having to buy one by one.. somesort deal with incentives would be good !
ebr 16344 Posted May 19, 2014 Posted May 19, 2014 Plug-ins are all built by different individual developers - like apps in the Google Play Store.
saajan4u 79 Posted May 25, 2014 Author Posted May 25, 2014 One last query for this.. (hopefully) please correct me I might be wrong.. does the movie theme video work for roku too or is it just the theme songs? If so mine doesnt work I have enabled it in the roku mb setting. What am I doing wrong? used tapatalk on me Samsung S4
