md_heuler 2 Posted June 27, 2019 Posted June 27, 2019 Mostly, yes. Simply to keep .nfo, subtitles, etc. together. But for some shows my library also contains *.mkv directly in season folder. I would say the latter is much less common.
Luke 42221 Posted June 27, 2019 Posted June 27, 2019 There is an issue with using episode folders that is resolved for the next release. Thanks.
Happy2Play 9806 Posted June 27, 2019 Posted June 27, 2019 (edited) Mostly, yes. Simply to keep .nfo, subtitles, etc. together. But for some shows my library also contains *.mkv directly in season folder. I would say the latter is much less common. Can you go over a specific example, as discussion above would appear to be a naming scheme issue. Title/ Title.E01 Emby is somewhat strict when it comes to Series/TV. Edited June 27, 2019 by Happy2Play
md_heuler 2 Posted June 28, 2019 Posted June 28, 2019 (edited) Seems like I have meanwhile fixed the 'Title.E01' issue ... but here is another specific example I can't get a decent solution for: Azoren.Disc1-Disc3/ Season 1/ Azoren.2011.Disc1.3D.AVC.DTS.HD-MA5.1/ Azoren.2011.Disc1.3D.AVC.DTS.HD-MA5.1.iso Azoren.2011.Disc2.3D.AVC.DTS.HD-MA5.1/ Azoren.2011.Disc2.3D.AVC.DTS.HD-MA5.1.iso Azoren.2011.Disc3.3D.AVC.DTS.HD-MA5.1/ Azoren.2011.Disc3.3D.AVC.DTS.HD-MA5.1.iso They end up as just one multi part episode: Azoren 3D - Season 1 Episide: 11. Azoren.2011.Disc1.3D.AVC.DTS.HD-MA5.1 with parts: 1.3D.AVC.DTS.HD-MA5.1 2.3D.AVC.DTS.HD-MA5.1 3.3D.AVC.DTS.HD-MA5.1 Edited June 28, 2019 by md_heuler
Luke 42221 Posted June 28, 2019 Posted June 28, 2019 Seems like I have meanwhile fixed the 'Title.E01' issue ... but here is another specific example I can't get a decent solution for: Azoren.Disc1-Disc3/ Season 1/ Azoren.2011.Disc1.3D.AVC.DTS.HD-MA5.1/ Azoren.2011.Disc1.3D.AVC.DTS.HD-MA5.1.iso Azoren.2011.Disc2.3D.AVC.DTS.HD-MA5.1/ Azoren.2011.Disc2.3D.AVC.DTS.HD-MA5.1.iso Azoren.2011.Disc3.3D.AVC.DTS.HD-MA5.1/ Azoren.2011.Disc3.3D.AVC.DTS.HD-MA5.1.iso They end up as just one multi part episode: Azoren 3D - Season 1 Episide: 11. Azoren.2011.Disc1.3D.AVC.DTS.HD-MA5.1 with parts: 1.3D.AVC.DTS.HD-MA5.1 2.3D.AVC.DTS.HD-MA5.1 3.3D.AVC.DTS.HD-MA5.1 Have you compared these file names to our supported TV Naming Conventions ?
