yucca1960 0 Posted May 11, 2019 Posted May 11, 2019 Hi, I been using emby server for years with no problems in one computer (24/7) that I used as my server but looking for a way of protecting my media I decided to build a freenas server, everything have gone fine until I started streaming movies with MPC-HC as an external player, when streaming the movies it does it as stream.asf and so only stereo audio no subtitles, also the Emby app take about 69 seconds to open. also if I use the emby internal player it work fine. any help will be appreciated (dont know much about computers but i read a lot and try to follow instructions) thanks freenas 11.2 U3 emby 4.0.2.0_1
Luke 42239 Posted May 11, 2019 Posted May 11, 2019 Hi there, what Emby app are you launching mpc-hc from?
yucca1960 0 Posted May 11, 2019 Author Posted May 11, 2019 Hi Luke, thanks for answering, the app that I am using is emby for media center
