teetniin 0 Posted May 11, 2019 Posted May 11, 2019 I'm having problems with latest Emby for few months. First Emby stopped after some time. Right now things have gotten worse. Service stops after starting. Heres latest bit of the log: 2019-05-08 09:26:09.180 Error Main: Error in appHost.Init *** Error Report *** Version: 4.1.1.0 Command line: /volume1/@appstore/EmbyServer/releases/4.1.1.0/EmbyServer.dll -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/pac$ Operating system: Unix 3.10.105.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///volume1/@appstore/EmbyServer/3rdparty/netcore/2.2.1/runtime/System.Private.CoreLib.dll Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/4.1.1.0 System.Net.HttpListenerException: System.Net.HttpListenerException (98): Address already in use at SocketHttpListener.Net.HttpEndPointManager.GetEPListener(ILogger logger, String host, Int32 port, HttpListener listener, Boolean secure) at SocketHttpListener.Net.HttpEndPointManager.AddPrefixInternal(ILogger logger, String p, HttpListener listener) at SocketHttpListener.Net.HttpEndPointManager.AddListener(ILogger logger, HttpListener listener) at SocketHttpListener.Net.HttpListener.Start() at Emby.Server.Implementations.ApplicationHost.StartServer() at Emby.Server.Implementations.ApplicationHost.Init() at EmbyServer.HostedService.StartAsync(CancellationToken cancellationToken) Source: SocketHttpListener TargetSite: SocketHttpListener.Net.HttpEndPointListener GetEPListener(MediaBrowser.Model.Logging.ILogger, System.String, Int32, SocketHttpListener.Net.HttpList$
Luke 42242 Posted May 11, 2019 Posted May 11, 2019 Hi there @@teetniin, can you please attach the complete emby server log? thanks.
teetniin 0 Posted May 11, 2019 Author Posted May 11, 2019 (edited) I used this method: https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs Is there better way for You? sendlogs_20190511T044948UTC.log Edited May 11, 2019 by teetniin
Luke 42242 Posted May 11, 2019 Posted May 11, 2019 If you don't mind, attaching to this thread would be best. Just click "more reply options" next to the Post button. Thanks !
Luke 42242 Posted May 11, 2019 Posted May 11, 2019 Hi there, can you try rebooting the NAS? Something has a hold on the port preventing the server from binding to it. Thanks.
teetniin 0 Posted May 11, 2019 Author Posted May 11, 2019 Seems to work. Now i have set up Emby server again. Week ago i tried also unininstall / install. Thanks!
