chowbok 136 Posted May 11, 2019 Posted May 11, 2019 I'm not able to import CSV files into my spreadsheet program correctly because the Reports plugin uses semicolons for delimiters but doesn't escape or quote the semicolons used to separate multiple genres. Can this be fixed? Thanks...
chowbok 136 Posted May 11, 2019 Author Posted May 11, 2019 It should enclose any field that has a semicolon in double quotes, e.g., ;x;x;x;The Maltese Falcon;4/25/19 11:20 PM;10/17/41 6:00 AM;1941;Mystery; Crime; Thriller;Not Rated;8.1;101mn;VC1;1920 * 1080;FLAC;x;x;x Should instead be ;x;x;x;The Maltese Falcon;4/25/19 11:20 PM;10/17/41 6:00 AM;1941;"Mystery; Crime; Thriller";Not Rated;8.1;101mn;VC1;1920 * 1080;FLAC;x;x;x
