GhostRider 49 Posted May 10, 2019 Posted May 10, 2019 Hi Since upgrading to version 4 of Emby server the genre pictures in Emby Theatre v 3.0.8 on a Windows 10 HTPC are displayed as squares. How do I get the protrait view back please? I use a CSS setting recommended on this forum for the Web interface. I am looking for a way to restore the protrait view in Emby Theatre as well. Is it possible please?
Luke 42242 Posted May 10, 2019 Posted May 10, 2019 Hi, we don't currently have any options for this. It auto-detects based on the aspect ratio of your genre images. have you customized those images?
GhostRider 49 Posted May 10, 2019 Author Posted May 10, 2019 Hi @@Luke No I am not using custom images, just those used in v 3 and available on Github. Version 3 icons are in the metadata folder and are being used but are cropped to square format.
GhostRider 49 Posted May 10, 2019 Author Posted May 10, 2019 Hi @@Luke Sure an example screenshot example is:
GhostRider 49 Posted May 10, 2019 Author Posted May 10, 2019 Do you see the same thing in the web app? Hi @@Luke, no in the web app I see protrait iamges because I am using a custom CSS as recommended in these forums: /*Genre padding to portrait*/ [data-type=MusicGenre] div.cardPadder-square, [data-type=Genre] div.cardPadder-square {padding-bottom: 150%;} Without the above the genre icons are square in the web app.
Luke 42242 Posted May 10, 2019 Posted May 10, 2019 I'm surprised that it's not auto-detecting the aspect ratio of those images.
GhostRider 49 Posted May 11, 2019 Author Posted May 11, 2019 Thanks @@Luke, do you thing this is an issue with 3.0.8? Before upgrading I had version 3.0.6 and the icons were displayed in portrait format. So many things changed during this time so maybe not a 3.0.8 issue but things were fine in 3.0.6.
Luke 42242 Posted May 11, 2019 Posted May 11, 2019 I was able to chase this down. It's resolved for the next release of the server, thanks. 1
