theghost31 4 Posted June 11, 2019 Author Posted June 11, 2019 (edited) Hi this issue is come back on latest version in beta . Try to return on 4.2.0.14 same issue. I come back to 4.1.0.14 and its working again :/But for sure, you changed / broken something since this version @@Luke Edited June 17, 2019 by theghost31
theghost31 4 Posted July 17, 2019 Author Posted July 17, 2019 (edited) @@Luke, again with the scenario as I said before ! My users told me, this happens, every day, after a 'pause'You look almost the half, put in 'pause' the episode. Come back later or tomorrow and continues it clicking on 'play' . you will see that the subtitles disappears forever, even after a refresh of the episode with F5 in the browser. Again this problem is not present until: 4.1.0.14, could you please check this problem very ennoying ? Thank you in advance Edited July 17, 2019 by theghost31
theghost31 4 Posted July 18, 2019 Author Posted July 18, 2019 I'm running in 4.1.0.28. I will update it, but I have an auto update with Docker scheduled every Sunday. So do you think, you fixed it between 4.1.0.28 and 4.1.0.31 (less one week between them)? If you think it is, I will give a try forcing today the update.
Luke 42217 Posted July 19, 2019 Posted July 19, 2019 There is an issue of videos stopping near the end that was resolved in the beta.
theghost31 4 Posted July 19, 2019 Author Posted July 19, 2019 Yep thanks for this issue. I will tell you if the problem appears again or not But I was talking about subtitles and subrip ect which disappear after a pause ')
ms78mama 1 Posted August 1, 2019 Posted August 1, 2019 The same problem i have as well Server version 4.2.0.40 with Emby for Android TV app. When you quite and resume a movie either there are no subs or when you force select they are out of sync. NOTE : This is only observed when using the app.
Luke 42217 Posted September 10, 2019 Posted September 10, 2019 Please try this again when Emby Server 4.3 is released. Thanks.
