Q-Droid 1011 Posted June 4, 2019 Posted June 4, 2019 I am using Apache 2 as my reverse proxy. Do you have any other suggestion I can put on my reverse proxy to aid in at least making these apps also work? Here is my configuration. Have you considered using ProxyPass and LocationMatch directives instead of rewrites? I'm no expert but I have used Apache and mod_proxy for some basic reverse proxy stuff. I found that ProxyPass[Reverse] were simpler to user rather than trying to identify and rewrite.
pir8radio 1313 Posted June 4, 2019 Posted June 4, 2019 No, it isn't a certificate issue. His proxy is not passing along the post data for the requests. I'm afraid the only solution we've seen so far is using nginx instead... Oh I see.... Yea I dont know enough about apache but nginx works in a proxypass/locationmatch setup... I wouldnt try to rewrite everything... Like Q-Droid said. Look into those methods, if you give up we can get you rolling with nginx
tshegofatso100 2 Posted June 7, 2019 Posted June 7, 2019 Thank you very much... Ill have to try to setup nginx And ill will feedback to you one i have it all setup.
pir8radio 1313 Posted June 7, 2019 Posted June 7, 2019 Thank you very much... Ill have to try to setup nginx And ill will feedback to you one i have it all setup. If you go to my user profile by clicking my avatar there is a link to a windows version of nginx (if you use windows) and a link to a good starting config for nginx.
tshegofatso100 2 Posted June 9, 2019 Posted June 9, 2019 (edited) If you go to my user profile by clicking my avatar there is a link to a windows version of nginx (if you use windows) and a link to a good starting config for nginx. Works like a charm. So the conclusion is NGINX is the best. I moved all the apache2 config to nginx and i am happy. Thank for the support Edited June 9, 2019 by tshegofatso100 2
pir8radio 1313 Posted June 9, 2019 Posted June 9, 2019 Works like a charm. So the conclusion is NGINX is the best. I moved all the apache2 config to nginx and i am happy. Thank for the support Good work! Lol and welcome to nginx!! [emoji846] Sent from my iPhone using Tapatalk
