igeoorge 26 Posted May 8, 2019 Posted May 8, 2019 Hello friends. After the last update of the Server, I am having problems converting the files. Previously at the moment of converting, the files that were dual audio were only with a single audio. Today, after converting files that are dual audio continues dual audio, however, only one audio is converted. Example; In a Dual Audio movie as in the picture, the main audio, Portuguese, is normally converted and the secondary audio, English, is not converted. In previous versions the secondary audio was deleted, leaving only the main audio. Is there any way to solve this problem? Thank you all.
Luke 42219 Posted May 9, 2019 Posted May 9, 2019 HI, we made the change to have the conversion process keep all audio tracks. Are you saying that this is a problem?
igeoorge 26 Posted May 9, 2019 Author Posted May 9, 2019 Hi how are you? All audio tracks can continue in the file is very good. The problem is that Emby only converts the default track. The second track is not always converted.
Luke 42219 Posted May 12, 2019 Posted May 12, 2019 Can you give an example of when it was not converted? Thanks !
