pflynn001 1 Posted May 7, 2019 Posted May 7, 2019 is there a setting for this I am missing on Nvidia Shield?
Luke 42237 Posted May 8, 2019 Posted May 8, 2019 Hi, it's automatic. Just run the server app and then it will be enabled for next boot.
aritafari 1 Posted May 11, 2019 Posted May 11, 2019 is there a setting for this I am missing on Nvidia Shield? I too have this issue. I have to manually enable Emby Server each and every time I restart Nvidia Shield. Yes. All apps are up to date / "Run server at startup" is enabled
Luke 42237 Posted May 12, 2019 Posted May 12, 2019 The setting is in the android UI, there is a toggle button "Enable Emby Server". That needs to be toggled to on.
Luke 42237 Posted May 12, 2019 Posted May 12, 2019 Also keep in mind if you install the app onto an SD card, then it will not be allowed to autorun.
Solution aritafari 1 Posted May 12, 2019 Solution Posted May 12, 2019 Also keep in mind if you install the app onto an SD card, then it will not be allowed to autorun. Fixed. Thanks for the quick response. My previous setup was 16gb NS / 200gb External formatted as "Adoptable Storage" I switched from Adoptable to Portable Storage and that seemed to have fixed it. 1
