mickg 0 Posted May 7, 2019 Posted May 7, 2019 (edited) When streaming music and moving from a wifi location (my house) to mobile data (my car) the stream will stop after finishing the current song that is playing, and the app will then appear to hang with the spinning indicator spining over and over and I will have to kill the app and then restart the app to be able to play any other media. Is this normal or is there a setting that I am missing? I am using ver. Version 4.0.2.0 on my server. Edited May 7, 2019 by mickg
Luke 42244 Posted May 7, 2019 Posted May 7, 2019 Hi, if the network connection is changing during playback then you may just need to restart playing. This is an area where we can improve on in the future. Thanks.
mickg 0 Posted May 8, 2019 Author Posted May 8, 2019 Ok yes I tested restarting playing and that does work. Thank you.
