heula 192 Posted May 31, 2019 Author Posted May 31, 2019 @@heula Restart Emby for Kodi, you should see a new pafch applied. Bring your libraries up to date once more. This time, if should keep up. The issue was related to newly added shows (or maybe the show was empty previously?). Anyway, I ensure to add the episodes if the show is added via live updates/fast sync. That should correct what you are seeing. Thanks, I will post an update when I know if this works or not.
heula 192 Posted June 3, 2019 Author Posted June 3, 2019 It does update now but some of the new added episodes are double. In the widget but also in the serie itself. Only one file on my NAS. This on my PC and Shield TV. PC log kodi PC.log Shield TV log kodi Shield TV.log 1
Angelblue05 4132 Posted June 4, 2019 Posted June 4, 2019 (edited) @@heula To understand what happened, I'll need the ids associated with the episodes that are duplicated. Could you please try to play each episode and provide a new kodi log? Thank you. Edited June 4, 2019 by Angelblue05
heula 192 Posted June 4, 2019 Author Posted June 4, 2019 (edited) @@heula To understand what happened, I'll need the ids associated with the episodes that are duplicated. Could you please try to play each episode and provide a new kodi log? Thank you. Played both Fear the walking dead 5x1 episodes, this is the log. kodi PC 4-6-2019.log Edited June 4, 2019 by heula 1
Angelblue05 4132 Posted June 5, 2019 Posted June 5, 2019 (edited) @@heula Thanks for the log, I am working on a fix. Please do still update to the latest beta. The issue is that the episode adds the show which then adds the episode (which initiated this). Have to prevent that. Edited June 6, 2019 by Angelblue05 1
Solution Angelblue05 4132 Posted June 6, 2019 Solution Posted June 6, 2019 @@heula Restart Kodi, you'll see a new patch applied. Repair the libraries to remove the duplicates. Let me know if the issue is resolved. I believe the issue was that the episode adds the show which then tries to add the episode (which initiated this). That caused the duplicate (the integrity errors) 1
heula 192 Posted June 7, 2019 Author Posted June 7, 2019 (edited) @@heula Restart Kodi, you'll see a new patch applied. Repair the libraries to remove the duplicates. Let me know if the issue is resolved. I believe the issue was that the episode adds the show which then tries to add the episode (which initiated this). That caused the duplicate (the integrity errors) After aplying the patch and updating the libraries the issue still remains. Not with all episodes but with some, For example, today the episode Beste Kijkers NL 6x4 is double. All older double episodes also still exist. kodi PC.log kodi PC.old.log Edited June 7, 2019 by heula
horstepipe 423 Posted June 7, 2019 Posted June 7, 2019 After aplying the patch and updating the libraries the issue still remains. Not with all episodes but with some, Hey just to be sure: Did you really repair the library or did you press refresh? Best regards 1
horstepipe 423 Posted June 7, 2019 Posted June 7, 2019 All older double episodes also still exist. I'm asking because you're really not supposed to see that after a library repair from my experience. 1
heula 192 Posted June 7, 2019 Author Posted June 7, 2019 I'm asking because you're really not supposed to see that after a library repair from my experience. No you are right. I updated instead or repairing. Doning that right now. 1
Angelblue05 4132 Posted June 8, 2019 Posted June 8, 2019 @@heula Still having this issue with newly added content?
heula 192 Posted June 11, 2019 Author Posted June 11, 2019 @@heula Still having this issue with newly added content? Sorry for the late reaction. After the last updates and repair of the libraries it seems to go well now. Thanks. 1
Angelblue05 4132 Posted June 11, 2019 Posted June 11, 2019 Sorry for the late reaction. After the last updates and repair of the libraries it seems to go well now. Thanks. That is great to hear! Thank you for reporting back.
heula 192 Posted June 26, 2019 Author Posted June 26, 2019 Again I'm having issues but this time only on my Shield TV. New episodes are going well but deleted items are not removed from the library. They are deleted because on the PC the deleted episodes are all gone. On Shield TV the episodes are still visible but when I select one a message appears that the episode is no longer available in the library and asks me if I want to remove it from the library. Emby for Kodi is up to date on Shield TV and PC. Running Emby server version 4.2.0.12 kodi Shield TV.log kodi Shield TV.old.log kodi PC.log 1
Angelblue05 4132 Posted June 26, 2019 Posted June 26, 2019 Thanks for reporting @@heula If I don't manage to find the fix right away, I will still release a new stable version because some api changes can't wait any longer, but I will keep you posted. It does seem like there was an issue on your shield regarding connection and then that resulted in an unusual error in the add-on. I will take a deeper look. 1
Glyde62 50 Posted June 28, 2019 Posted June 28, 2019 Again I'm having issues but this time only on my Shield TV. New episodes are going well but deleted items are not removed from the library. They are deleted because on the PC the deleted episodes are all gone. On Shield TV the episodes are still visible but when I select one a message appears that the episode is no longer available in the library and asks me if I want to remove it from the library. Emby for Kodi is up to date on Shield TV and PC. Running Emby server version 4.2.0.12 kodi Shield TV.log kodi Shield TV.old.log kodi PC.log Having same problem on my shield also Sent from my LYA-L09 using Tapatalk
Angelblue05 4132 Posted June 28, 2019 Posted June 28, 2019 Is this a recent issue? What server version are you on? I haven't been able to replicate this yet. Are we sure it's not bad entries from the past when I was trying to fix this issue?
mobamobamoba 5 Posted July 1, 2019 Posted July 1, 2019 (edited) Is this a recent issue? What server version are you on? I haven't been able to replicate this yet. Are we sure it's not bad entries from the past when I was trying to fix this issue? I have this same issue and it showed up recently (using Kodi on Win10). I delete a show and it properly deletes in Emby and on the PC but still shows up in Kodi and won't disappear unless you go in and force a manual library repair. Edited July 1, 2019 by mobamobamoba 1
heula 192 Posted July 2, 2019 Author Posted July 2, 2019 I have seen two Emby Server updates and I thought one addon update but still the deleted items remain in the library. Yesterday deleted several episodes of L.A's Finest, they are deleted but still visible on my Shield TV. When I take a look on my pc they are gone. When I delete an episode on my pc it disappears almost instantly. I do see now a progress bar on top of the screen in Kodi. New items are still no issue. kodi.log Thanks. 1
Glyde62 50 Posted July 2, 2019 Posted July 2, 2019 Had shows that we watched and Emby deleted them, But this afternoon they were showing again Doing a library repair fixed it though Sent from my LYA-L09 using Tapatalk 1
Glyde62 50 Posted July 4, 2019 Posted July 4, 2019 No fix for this problem Watched shows still showing after Emby deleted them Disappear but later show in library again Sent from my LYA-L09 using Tapatalk
Angelblue05 4132 Posted July 4, 2019 Posted July 4, 2019 I am working on fixing this situation, thanks again for your patience. I'll let you know if I need anything more. 2
Angelblue05 4132 Posted July 5, 2019 Posted July 5, 2019 Are you guys using the beta server by any chance?
Glyde62 50 Posted July 5, 2019 Posted July 5, 2019 Are you guys using the beta server by any chance?Let me check....... 4.1.1.0-1 doesn't say beta anywhere That's on my Synology btw Sent from my LYA-L09 using Tapatalk 1
Angelblue05 4132 Posted July 5, 2019 Posted July 5, 2019 (edited) Ok then you likely don’t have the same issue as heula. Did you provide your Kodi log? How can I replicate the behavior for myself? What’s your file structure? Thanks. Edited July 5, 2019 by Angelblue05
