Angelblue05 4132 Posted May 10, 2019 Posted May 10, 2019 (edited) Something is definitely up with your live updates. @@Seger Can you sideload 4.0.20e? Install from zip > kodi.emby.media > public testing Let me know if the issue persists. If it does, can you also confirm in the webclient, that the Kodi player is indeed available to be controlled via the play to option (the cast icon in the webclient). I'm not seeing live updates in your logs, that's why a restart is needed. Live updates are sent via the websocket connection, I don't see any errors regarding that in your log, but nothing is sent to it so the add-on does not do anything. Edited May 10, 2019 by Angelblue05
Angelblue05 4132 Posted May 10, 2019 Posted May 10, 2019 (edited) @@popy I do see an issue with your scenario. It just restarts the websocket which was disconnected. It does not grab updates that happened while it was disconnected. I'll make some adjustments. Edited May 10, 2019 by Angelblue05 1
Angelblue05 4132 Posted May 10, 2019 Posted May 10, 2019 @@heula I saw something strange in your logs. I am still looking for an explanation. Essentially, updates are received, it processed deletion... leaving content updates unprocessed it seems. I'm not sure how that happened. I will let you know as soon as I find out more. Thanks for your patience. 1
popy 73 Posted May 10, 2019 Posted May 10, 2019 @@popy I do see an issue with your scenario. It just restarts the websocket which was disconnected. It does not grab updates that happened while it was disconnected. I'll make some adjustments. thx, take your time, just let me know. I am here to test. pOpY PS.: should ill upgrade my emby server or can i leave it at Version 4.0.0.2 ?
Seger 123 Posted May 10, 2019 Posted May 10, 2019 (edited) Something is definitely up with your live updates. @@Seger Can you sideload 4.0.20e? Install from zip > kodi.emby.media > public testing Let me know if the issue persists. If it does, can you also confirm in the webclient, that the Kodi player is indeed available to be controlled via the play to option (the cast icon in the webclient). I'm not seeing live updates in your logs, that's why a restart is needed. Live updates are sent via the websocket connection, I don't see any errors regarding that in your log, but nothing is sent to it so the add-on does not do anything. no change, addon updated, favorite removed at 21:12 and nothing happens in Kodi, moreover, the change will be implemented only after a reboot. in the dashboard he shows me the Kodi instance, but there are funny characters with fritz.box available (see picture). I also have a real time problem like many others right now, but that only affects the server, it certainly will have nothing to do with it: https://emby.media/community/index.php?/topic/69684-emby-version-4-real-time-monitoring-is-not-working-synology-241315-and-all-other/?p=736073 Edited May 10, 2019 by Seger
Angelblue05 4132 Posted May 10, 2019 Posted May 10, 2019 (edited) No that is not what I asked you to check in the webclient @@Seger Your issue is regarding the websocket connection I am pretty sure. <--- I just reread your post. As long as new content appears on your server, then yes you are correct, your real-time monitor is not the issue. But you still have the problem with the server to Kodi due to the websocket connection. Does Kodi appear when you click Play to here. It's the quickest way to confirm if it's an issue with the websocket connection. Edited May 10, 2019 by Angelblue05
Seger 123 Posted May 10, 2019 Posted May 10, 2019 No that is not what I asked you to check in the webclient @@Seger Your issue is regarding the websocket connection I am pretty sure. <--- I just reread your post. As long as new content appears on your server, then yes you are correct, your real-time monitor is not the issue. But you still have the problem with the server to Kodi due to the websocket connection. Does Kodi appear when you click Play to here. It's the quickest way to confirm if it's an issue with the websocket connection. okay there's not happening at all, the server only loads and it does not open a menu. enclosed the log from the server. 1
Angelblue05 4132 Posted May 10, 2019 Posted May 10, 2019 @@Luke Do you see something in the server log from the previous post regarding the websocket?
Luke 42237 Posted May 10, 2019 Posted May 10, 2019 No, the log looks normal to me. Are you able to control other web app sessions, like if you open one in Chrome and one in Firefox? 1
Seger 123 Posted May 10, 2019 Posted May 10, 2019 @@Luke @@Angelblue05 yes, if I choose from chrome streaming then I can quite normal stream on my shield. However, kodi is not displayed there. slowly I think that my server is somehow buggy. in the real time supply, the lack of establishing the connection and then the topic that is not loaded in new series, the background image. everything does not really have anything to do with stable ... :-( How should I proceed now? thank you guys
Angelblue05 4132 Posted May 10, 2019 Posted May 10, 2019 (edited) @@Seger Ok, can you try the following. Turn off Kodi. In the Emby server dashboard > Devices > Find the Kodi device then 3 dots > Delete. You will need to reauthenticate in Kodi, but then does this help? Try to do the Play to select again, does Kodi show up? Edited May 10, 2019 by Angelblue05
Seger 123 Posted May 10, 2019 Posted May 10, 2019 (edited) update: now he has just displayed all my devices, have restarted everything. but the real mistake remains. when I select the kodi device and what plays he shows me a play bar in the browser to synonymous running, but it is not a movie to see. attached again the log ... Edited May 10, 2019 by Seger
Angelblue05 4132 Posted May 10, 2019 Posted May 10, 2019 What you mean by this? but it is not a movie to see. Unbenannt.JPG Can you try to play something in Kodi, stop playback after a minute. Wait a bit then post your Kodi log.
Seger 123 Posted May 10, 2019 Posted May 10, 2019 (edited) @@Angelblue05 UPDATE AND SOLUTION :-): So delete the tip with the device and then in Emby for Kodi was the cure! Then the connection works again immediately! the streaming is now synonymous again, was just just a bar without picture in kodi. Now the connection is restored and played. the favorites will be immediately removed or added. was probably a mistake in the original connection. Now only the other errors remain from the other thread, but there is @@Luke turn. Many thanks! If I should test something, always like to come here. many Greetings, seger Edited May 10, 2019 by Seger 1
Angelblue05 4132 Posted May 10, 2019 Posted May 10, 2019 Yup, it looks normal now. Don't forget to delete your logs from your posts.
Seger 123 Posted May 10, 2019 Posted May 10, 2019 (edited) You Bought @@Angelblue05 a coffee! ;-) Edited May 10, 2019 by Seger 1
popy 73 Posted May 11, 2019 Posted May 11, 2019 @Angelblue05: is this 4.0.20e test version also for my issue? Thanks a lot pOpY
Angelblue05 4132 Posted May 11, 2019 Posted May 11, 2019 No. Yours should be fixed with the next beta version. I have a few things left to fix. Hopefully later today. 1
horstepipe 423 Posted May 11, 2019 Posted May 11, 2019 @@Angelblue05 UPDATE AND SOLUTION :-): So delete the tip with the device and then in Emby for Kodi was the cure! Then the connection works again immediately! the streaming is now synonymous again, was just just a bar without picture in kodi. Now the connection is restored and played. the favorites will be immediately removed or added. was probably a mistake in the original connection. Sorry seger but I don't 100% understand what you did to fix your problem. Did you only clean up the device list in Emby server?
popy 73 Posted May 11, 2019 Posted May 11, 2019 No. Yours should be fixed with the next beta version. I have a few things left to fix. Hopefully later today. No problem. Just let me know. THANKS A LOT! pOpY
Angelblue05 4132 Posted May 11, 2019 Posted May 11, 2019 @@horstepipe @@Seger Ok, can you try the following. Turn off Kodi. In the Emby server dashboard > Devices > Find the Kodi device then 3 dots > Delete. You will need to reauthenticate in Kodi, but then does this help? Try to do the Play to select again, does Kodi show up? 1
Angelblue05 4132 Posted May 12, 2019 Posted May 12, 2019 (edited) @@heula Ok I checked your log. Your server keeps timing out when the add-on tries to retrieve your updates, that's why nothing happens. Not sure why, but I've set it to retry it. You also have a shortcut that never loads in your skin. Can you remove it? Homevideos (8fe38898df089944b7a35f5183e1cc20) recently added or at least confirm if it ever loads? Let's retry with 4.0.21a. I've made a few adjustments around what I saw in your logs. Edited May 12, 2019 by Angelblue05
Angelblue05 4132 Posted May 12, 2019 Posted May 12, 2019 @@popy Please try 4.0.21 and let me know if it resolves your issue. @@alturismo Without a Kodi log, I can't help you much. Was Kodi running at the time or is this an issue only when Kodi has been offline? 1
heula 192 Posted May 12, 2019 Author Posted May 12, 2019 @@heula Ok I checked your log. Your server keeps timing out when the add-on tries to retrieve your updates, that's why nothing happens. Not sure why, but I've set it to retry it. You also have a shortcut that never loads in your skin. Can you remove it? Homevideos (8fe38898df089944b7a35f5183e1cc20) recently added or at least confirm if it ever loads? Let's retry with 4.0.21a. I've made a few adjustments around what I saw in your logs. Where can I find this "Homevideos (8fe38898df089944b7a35f5183e1cc20)"? I searched in Kodi and in the Emby Server but nothing is found there.
Angelblue05 4132 Posted May 12, 2019 Posted May 12, 2019 (edited) It looks to be a widget shortcut. So in Kodi, your skin, check your widgets. You don't have a library with that id (you can confirm by viewing the library in the webclient, check the id in the url)? That might be what's causing your server to timeout? 2019-05-07 07:54:16.115 T:11416 NOTICE: EMBY.entrypoint.default -> path: ?folder=RecentlyAdded&server=None&type=homevideos&id=8fe38898df089944b7a35f5183e1cc20&mode=browse&reload=20190507055310 params: { "server": "None", "reload": "20190507055310", "mode": "browse", "folder": "RecentlyAdded", "type": "homevideos", "id": "8fe38898df089944b7a35f5183e1cc20" } Edited May 12, 2019 by Angelblue05
