snazy2000 344 Posted May 29, 2014 Author Posted May 29, 2014 Yeah I think the system core should just not show the other display options if there's a limit @@Luke Sent from my HTC One using Tapatalk 1
Abobader 3485 Posted May 29, 2014 Posted May 29, 2014 Yeah I think the system core should just not show the other display options if there's a limit @@Luke Sent from my HTC One using Tapatalk +1 Or every categories/channels have it own display filter.
Sven 136 Posted May 30, 2014 Posted May 30, 2014 I installed the vimeo plugin. But i get this. What do you need on the config page? I don't find any access token on vimeo....
snazy2000 344 Posted May 30, 2014 Author Posted May 30, 2014 You enter the link in your browser and agree then you see the access code. Sent from my HTC One using Tapatalk
Sven 136 Posted May 30, 2014 Posted May 30, 2014 You enter the link in your browser and agree then you see the access code. Sent from my HTC One using Tapatalk Indeed, thanks
snazy2000 344 Posted May 30, 2014 Author Posted May 30, 2014 I need to make it more clear at some point Sent from my HTC One using Tapatalk
SikSlayer 254 Posted May 31, 2014 Posted May 31, 2014 Minor issue I'm having withthe Twitch channel. When I click on Channels in the web client, I see logos for Vimeo, Revision 3, and Trailers, but not for Twitch. It's there when I uninstall the plugin and go to get a new one, but not after its installed. I've seen screenshots that it should have the logo, so maybe something is wrong on my end. Any ideas?
snazy2000 344 Posted May 31, 2014 Author Posted May 31, 2014 Hmm I will take look later Sent from my HTC One using Tapatalk 1
SikSlayer 254 Posted June 5, 2014 Posted June 5, 2014 Hmm I will take look later Only the 'primary' image was there. I had to copy the 'backdrop' image from the catalog, and paste it, as well as a copy named 'thumbs' into the \AppData\Roaming\MediaBrowser-Server\ImagesByName\channels\Twitch TV folder, and then point to it by highlighting the channel, and clicking that little pencil icon to manually enter them. I noticed later that the other plugins don't have any images in their folders, so while I've 'fixed' my issue, the core cause wasn't. Hope you find time to take a look.
Abobader 3485 Posted June 5, 2014 Posted June 5, 2014 Only the 'primary' image was there. I had to copy the 'backdrop' image from the catalog, and paste it, as well as a copy named 'thumbs' into the \AppData\Roaming\MediaBrowser-Server\ImagesByName\channels\Twitch TV folder, and then point to it by highlighting the channel, and clicking that little pencil icon to manually enter them. I noticed later that the other plugins don't have any images in their folders, so while I've 'fixed' my issue, the core cause wasn't. Hope you find time to take a look. Good day, Simply remove that image, then go to the web client for that plugin, mouse over it and click edit, then simply delete any image there, then do "full refresh", then the correct images will be download. My best 1
SikSlayer 254 Posted June 5, 2014 Posted June 5, 2014 Good day, Simply remove that image, then go to the web client for that plugin, mouse over it and click edit, then simply delete any image there, then do "full refresh", then the correct images will be download. My best That was forehead-slappingly simple. Now I feel stupid for not having tried that before. Thank you. 1
