cordo79 1 Posted November 13, 2019 Posted November 13, 2019 any one of this log? video of playback added logs.zip VID_20191113_165537.zip
cordo79 1 Posted November 13, 2019 Posted November 13, 2019 i have the same problem on the new shield, bad :-(
ebr 16338 Posted November 13, 2019 Posted November 13, 2019 Is the media info above for the same item? Do you know what the channel layout is for this item? It doesn't say but just says "6 channels" which would usually equate to 5.1 which isn't a problem. Maybe this is 6.0...
ebr 16338 Posted November 13, 2019 Posted November 13, 2019 Do you know what the channel layout is for this item? It doesn't say but just says "6 channels" which would usually equate to 5.1 which isn't a problem. Maybe this is 6.0...
cordo79 1 Posted November 13, 2019 Posted November 13, 2019 (edited) MediaInfo output on other tests my receiver said its ddplus 6.1 but its long time ago i can test again ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 3 min Bit rate : 47.0 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.236 Stream size : 40.6 GiB (87%) Title : Captain.Marvel.2019.German.UHDBD.2160p.HDR10.HEVC.EAC3.DL.Remux-pmHD Writing library : ATEME Titan File 3.9.0 (4.9.0.0) Language : German Default : Yes Forced : Yes Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0020 cd/m2, max: 1000 cd/m2 ID : 2 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Format profile : Blu-ray Disc Codec ID : A_EAC3 Duration : 2 h 3 min Bit rate mode : Constant Bit rate : 1 024 kb/s Channel(s) : 6 channels Channel(s)_Original : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : 1 ms Stream size : 906 MiB (2%) Title : German E-AC3 7.1 Language : German Service kind : Complete Main Default : Yes Forced : Yes ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 3 min Bit rate mode : Constant Bit rate : 576 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 510 MiB (1%) Title : German AC3 5.1-EX Language : German Service kind : Complete Main Default : No Forced : No ID : 4 Format : MLP FBA 16-ch Format/Info : Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Codec ID : A_TRUEHD Duration : 2 h 3 min Bit rate mode : Variable Bit rate : 4 613 kb/s Maximum bit rate : 7 317 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 1 200.000 FPS (40 SPF) Compression mode : Lossless Stream size : 3.99 GiB (9%) Title : English TrueHD Atmos 7.1 Language : English Default : No Forced : No Number of dynamic objects : 13 Bed channel count : 1 channel Bed channel configuration : LFE ID : 5 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 3 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 566 MiB (1%) Title : English AC3 5.1-EX Language : English Service kind : Complete Main Default : No Forced : No Edited November 13, 2019 by cordo79
ebr 16338 Posted November 13, 2019 Posted November 13, 2019 Where did this item come from? It is reporting the channel count incorrectly which is why the app is not playing it properly. It says it is 6 channels but it is actually 7.1.
ebr 16338 Posted November 13, 2019 Posted November 13, 2019 Where did this item come from? Can you re-rip or remux it? @@softworkz any idea how the channel count can get messed up like this and what is channels_original?
pünktchen 1411 Posted November 13, 2019 Posted November 13, 2019 Channels is from the container header and Channels Original from audio stream. Mkvtoolnix has problems to correctly identify and set the channel count for EAC3 audio tracks. You can correct the number within the header editor of mkvtoolnix or with mkvpropedit. 1
softworkz 5133 Posted November 14, 2019 Posted November 14, 2019 @@softworkz any idea how the channel count can get messed up like this and what is channels_original? "channels_original" is a field from the output of the MediaInfo application. It's nothing official or standardized but rather an "invention" of the MediaInfo developer and its naming is not really intuitive. The developer also states that "Cannels_Original" would be taken from the raw audio stream while Channels would be taken from the "container header". While I think that "stream metadata" would be a more valid naming, I can confirm what @@pünktchen already said: The source file is encoded incorrectly.
softworkz 5133 Posted November 14, 2019 Posted November 14, 2019 @@ebr @@Luke - edd generation will allow us to view media file data the same way as Emby sees it. We will no longer be dependent on 3rd party tools and wonder about the meaning of its output.
cordo79 1 Posted November 14, 2019 Posted November 14, 2019 i will try to change this but i dont know exatly what i have to change. anyone can explain more detailed ?
softworkz 5133 Posted November 14, 2019 Posted November 14, 2019 i will try to change this but i dont know exatly what i have to change. anyone can explain more detailed ? Download: https://mkvtoolnix.download/downloads.html#windows I hope this screenshot will explain: PS: To save the changes, use the "Header Editor" menu. 2
cordo79 1 Posted November 16, 2019 Posted November 16, 2019 Thanks. Now the stutter is gone when i dont change the audio channel while playing. When i start direct with this audio channel its ok. It transcode the audio to 5.1. reason is because to mutch audio channels
