IceBoosteR 10 Posted June 12, 2019 Author Posted June 12, 2019 @@ebr Any update on this? The files from @@mikeB2210 are great - it also includes the movie I have problems with.
ebr 16338 Posted June 12, 2019 Posted June 12, 2019 Sorry, I'm not sure what to do other than transcode them. I have a number of items with DD+ soundtracks though that play fine. I think maybe it is only 7.1...
Yog-Sothoth 2 Posted June 28, 2019 Posted June 28, 2019 Sorry, I'm not sure what to do other than transcode them. I have a number of items with DD+ soundtracks though that play fine. I think maybe it is only 7.1... Any solution? I have the same problem and I put the beta version of SHIELD... With KODI, no problem...
Luke 42246 Posted June 28, 2019 Posted June 28, 2019 Any solution? I have the same problem and I put the beta version of SHIELD... With KODI, no problem... @@Yog-Sothoth can you please go over an example? thanks !
BillOatman 597 Posted June 28, 2019 Posted June 28, 2019 (edited) same problem here with all DD+ Movies. When i use alternate player vlc or mx there is no stutter. Exoplayer problem? If that's the thought, and it does seem plausible, maybe checking with the players devs might make sense. And I'll also be "that guy" From the exoplayer site The FFmpeg extension supports decoding a variety of different audio sample formats. You can choose which decoders to include by passing command line arguments to FFmpeg’s configure script: TrueHD –enable-decoder=mlp –enable-decoder=truehd Edited June 28, 2019 by BillOatman
ebr 16338 Posted June 28, 2019 Posted June 28, 2019 If that's the thought, and it does seem plausible, maybe checking with the players devs might make sense. I have to try and pull together an example and see if it can be reproduced with their demo app before consulting them. And I'll also be "that guy" From the exoplayer site This isn't really relevant to this situation as we are passing thru this codec for outbound processing by a receiver - not using the ffmpeg extension for software decoding.
ebr 16338 Posted June 28, 2019 Posted June 28, 2019 @@Yog-Sothoth can you please go over an example? thanks ! I think we fully understand the issue at this point. It can be reproduced but only with certain content.
ebr 16338 Posted June 29, 2019 Posted June 29, 2019 I tried it allready, but the problem is not solved on my shield. Only playing this files in Kodi solved the problem. So I think its not shield problem. @@mikeB2210 I just want to confirm that you were running the experimental Shield firmware image you have to request from Nvidia directly - the one that fixes the other stuttering problems. Thanks.
mikeB2210 26 Posted June 30, 2019 Posted June 30, 2019 @@ebr yes I‘m running the experimental Firmware from NVidia. Stuttering Problem is gone, DD+ 7.1 still there. 1
mikeB2210 26 Posted July 1, 2019 Posted July 1, 2019 @@ebr have just played a movie with dd + 7.1 with the current 1.7.33g. the jerking is gone, but only 5.1 channels are played as sound.
ebr 16338 Posted July 1, 2019 Posted July 1, 2019 Correct. That is the workaround until we can get with Google to try and find out what the problem is. Thanks. 1
mikeB2210 26 Posted August 21, 2019 Posted August 21, 2019 Correct. That is the workaround until we can get with Google to try and find out what the problem is. Thanks. Any news solving this DD+ problem?? 1
mikeB2210 26 Posted November 8, 2019 Posted November 8, 2019 (edited) Good news ;-) The new Shield Pro 2019 plays DD+ 7.1 Sound without stuttering. I don‘t know if this problem is solved with new hardware or the firmware 8.1 solved the problem. Edited November 8, 2019 by mikeB2210
cordo79 1 Posted November 8, 2019 Posted November 8, 2019 (edited) Ahh great, thank you for this Information. Looking for this new device Edited November 12, 2019 by cordo79
ebr 16338 Posted November 9, 2019 Posted November 9, 2019 Good news ;-) The new Shield Pro 2019 plays DD+ 7.1 Sound without stuttering. I don‘t know if this problem is solved with new hardware or the firmware 8.1 solved the problem. How did you determine this?
mikeB2210 26 Posted November 9, 2019 Posted November 9, 2019 (edited) I can play the files, that doesn‘t play well in DD+ 7.1 with the old shield, with the new shield pro without problems. DD+ 7.1 works Edited November 9, 2019 by mikeB2210
ebr 16338 Posted November 9, 2019 Posted November 9, 2019 I can play the files, that doesn‘t play well in DD+ 7.1 with the old shield, with the new shield pro without problems. DD+ 7.1 works In what app? Our app is compensating for this problem in the Shield and I recently confirmed the issue still exists in 8.1.
mikeB2210 26 Posted November 9, 2019 Posted November 9, 2019 Oh shit - my mistake. My receiver shows DD+ and I think everything is working.
cordo79 1 Posted November 12, 2019 Posted November 12, 2019 what is your mistake? Product Description says it runs android 9.0 Pie And i hope very much this works now with this product. i will buy one now. old shield make problems with DD+. No one movie plays without stutter unless other audio is selected as dd+. (Emby and Plex) Only with Kodi i have no problem.
ebr 16338 Posted November 12, 2019 Posted November 12, 2019 old shield make problems with DD+. No one movie plays without stutter unless other audio is selected as dd+. (Emby and Plex) Only with Kodi i have no problem. Hi. Our app should not stutter with DD+ playback. If you are having a problem with this, please provide details of an example. Thanks!
cordo79 1 Posted November 12, 2019 Posted November 12, 2019 (edited) Its the same since my last example in june. Every Movie if i play it with DD+ it stutter very mutch. 5-6 seconds for next picture. very out of sync. All other Sound Profiles are ok. AND with Kodi no problem Example: Captain Marvel Video Title4K HEVCCodecHEVCProfilMain 10Level153Auflösung3840x2160Seitenverhältnis16:9AnamorphNoInterlacedNoBildrate23,976Bitrate54.040 kbpsVideo rangeHDRColor primariesbt2020Farbraumbt2020ncColor transfersmpte2084Pixelformatyuv420p10leRef Frames1 Audio TitleGerman Dolby Digital+ 6 ch (Default)SpracheGermanCodecEAC3Kanäle6 chSample-Rate48.000 HzVoreinstellungYes Audio TitleGerman Dolby Digital 5.1SpracheGermanCodecAC3Darstellung5.1Kanäle6 chBitrate576 kbpsSample-Rate48.000 HzVoreinstellungNo Audio TitleEnglish TRUEHD 7.1SpracheEnglishCodecTRUEHDDarstellung7.1Kanäle8 chSample-Rate48.000 HzBit-Tiefe24 bitVoreinstellungNo Audio TitleEnglish Dolby Digital 5.1SpracheEnglishCodecAC3Darstellung5.1Kanäle6 chBitrate640 kbpsSample-Rate48.000 HzVoreinstellungNo Edited November 12, 2019 by cordo79
ebr 16338 Posted November 12, 2019 Posted November 12, 2019 Hi. Do you have an ffmpeg log from that playback?
cordo79 1 Posted November 12, 2019 Posted November 12, 2019 no, when you want i can do one if you say me how :-)
ebr 16338 Posted November 12, 2019 Posted November 12, 2019 Instructions below. Thanks. How to Report a Problem
