jeremymeyers 4 Posted May 5, 2019 Posted May 5, 2019 I have a bunch of DVDs ripped that have commentary tracks/alternate audio tracks. I've been trying to replace them with HD video files. Many of these video files do not have the alternate audio tracks attached. IS there a way to copy the audio tracks from the original mkv to the new mkv? (i am aware that they might not sync up 100%
Luke 42240 Posted May 5, 2019 Posted May 5, 2019 Possibly using mkvtoolnix although I'm not sure. But that's a pretty robust tool for mkv editing.
rbjtech 5341 Posted May 5, 2019 Posted May 5, 2019 Yes, use gMKVExtractGUI to extract the commentary streams you want - then use mkvtoolnix and add the HD MKV. Then add the commentary streams, add the metadata, languages, commentary details etc. re-order the tracks as you see fit. then re-mux it all to a new MKV.
