pir8radio 1313 Posted May 4, 2019 Posted May 4, 2019 My iptv is direct streaming. I’m trying to follow the stats for nerds. So the stats say original media 20 Mbps but the “remuxed” video is only 3 Mbps? Shouldn’t it be about the same? Sent from my iPhone using Tapatalk
pir8radio 1313 Posted May 4, 2019 Author Posted May 4, 2019 It could be fluctuating during the video. It does from 2.99 to 3. But since I’m not transcoding to a bitrate that low, I would expect the streamed video to be closer to the original media bitrate right? I’m missing 17mbps somewhere lol. Sent from my iPhone using Tapatalk
Luke 42245 Posted May 4, 2019 Posted May 4, 2019 The source could fluctuate throughout the broadcast.
pir8radio 1313 Posted May 4, 2019 Author Posted May 4, 2019 The source could fluctuate throughout the broadcast. I’ll look at the logs. Thx. Sent from my iPhone using Tapatalk
Carlo 4561 Posted May 6, 2019 Posted May 6, 2019 My iptv is direct streaming. I’m trying to follow the stats for nerds. So the stats say original media 20 Mbps but the “remuxed” video is only 3 Mbps? Shouldn’t it be about the same? Sent from my iPhone using Tapatalk I'd actually use a different utility to look at the current bitrate of the original video. I doubt it's 20Mb especially if you recorded it.
pir8radio 1313 Posted May 6, 2019 Author Posted May 6, 2019 I'd actually use a different utility to look at the current bitrate of the original video. I doubt it's 20Mb especially if you recorded it. it was a live stream, no recording. mpegts
Luke 42245 Posted May 6, 2019 Posted May 6, 2019 if the probing process is unable to determine a bitrate then we estimate based on other information that we do know. So that could also explain it.
Carlo 4561 Posted May 7, 2019 Posted May 7, 2019 it was a live stream, no recording. mpegts If it was from a tuner like an HDHomeRun you can view the bitrate in the HDHomeRun web app. If it was from an M3U provider, it won't be no where near that high as they use compression to keep the bitrates down. You could always load the same stream in VLC or other program to pull that info.
