CharleyVarrick 284 Posted May 4, 2019 Posted May 4, 2019 Hi, this morning, for some reasons, Emby is constantly scanning my movies library. As soon as it reaches 100%, it restart the same scan of same library. Attached is Emby log. emby log.txt
CharleyVarrick 284 Posted May 4, 2019 Author Posted May 4, 2019 Nevermind, I am unexpectedly performing a full reinstall of Emby.
CharleyVarrick 284 Posted May 7, 2019 Author Posted May 7, 2019 I am surprised to report the original problem is back, after a full Emby reinstall. From Emby Home page, the small green circle (with % of library scanned) pops up over the movie library, jumps to 90% process the rest within 30-45 seconds, and disappear. 10 seconds later, it goes thru the same steps, endlessly it seems. Look at 14:35 and after, there was a scan a minute for a while. Log enclosed. embyserver.txt
Luke 42288 Posted May 7, 2019 Posted May 7, 2019 Hi, try turning off the realtime monitor for your emby libraries. To do this, click into the library settings for each library in Emby library setup. Thanks.
Happy2Play 9814 Posted May 7, 2019 Posted May 7, 2019 Only time I see something like this is if I add a lot of files or my other metadata provider (MCM) touches and/or updates a lot of files. So the staggered realtime monitor queues the changes. As a scan is running while another gets queued.
CharleyVarrick 284 Posted May 8, 2019 Author Posted May 8, 2019 (edited) Hi, try turning off the realtime monitor for your emby libraries. To do this, click into the library settings for each library in Emby library setup. Thanks. I turned it off for Movies library (as its the only one constantly updating), but it hasn't stopped the issue. Edited May 8, 2019 by jlr19
CharleyVarrick 284 Posted May 8, 2019 Author Posted May 8, 2019 (edited) Only time I see something like this is if I add a lot of files or my other metadata provider (MCM) touches and/or updates a lot of files. So the staggered realtime monitor queues the changes. As a scan is running while another gets queued. I'm adding "lots of files" in TV shows (10 or more) on a daily basis, but my Movies library is pretty quiet, maybe 3 additions a week. Edited May 8, 2019 by jlr19
CharleyVarrick 284 Posted May 8, 2019 Author Posted May 8, 2019 (edited) As a side effect, I noticed Emby does not update my busier tv shows library. Additional info: Restarting Emby. Constant scanning of movies library stops, but I as soon as I add content to movie library or Emby performs a scheduled scan of it, the continuous scan starts over. Edited May 8, 2019 by jlr19
Luke 42288 Posted May 8, 2019 Posted May 8, 2019 Make sure to restart the server after turning off the real-time monitor.
CharleyVarrick 284 Posted May 8, 2019 Author Posted May 8, 2019 (edited) Make sure to restart the server after turning off the real-time monitor. Done already Luke, Since restarting, Emby hasn't gone scan loop, but it didn't either process/add a few "test" content addition I throwed. Then again,to be expected with realtime monitor turned off. Speaking of which, should I turn it back on and see if scan loop resumes? Edited May 8, 2019 by jlr19
CharleyVarrick 284 Posted May 9, 2019 Author Posted May 9, 2019 (edited) So far so good, but I'm going to keep an eye out on it (btw, that hurts like hell, you have no idea... ) Edited May 9, 2019 by jlr19
CharleyVarrick 284 Posted May 9, 2019 Author Posted May 9, 2019 Sure. Within minutes after re enabling realtime monitor in Movies Library and rebooting, the issue is back, but this time its a different library. Should I go thru the same steps as before, but this time about the newly affected library?
CharleyVarrick 284 Posted May 10, 2019 Author Posted May 10, 2019 (edited) I went ahead and disabled realtime monitor on newly affected library, restarted the server and within hours, back to square 1: the original problem library (Movies) is scanned every minute. And like before, while this is going on, no other libraries gets updated. Edited May 10, 2019 by jlr19
CBers 7573 Posted May 10, 2019 Posted May 10, 2019 Can you see any file changes in the library in question? Do you perhaps have any other metadata program running that might be updating the said library/folder? Is this Windows install, or another OS?
CharleyVarrick 284 Posted May 10, 2019 Author Posted May 10, 2019 (edited) 1) Can you see any file changes in the library in question? 2) Do you perhaps have any other metadata program running that might be updating the said library/folder? 3) Is this Windows install, or another OS? 1) nothing stands out 2) Kodi, with help from Emby for Kodi, on two win10 machines 3) server runs on win7x64 Edited May 10, 2019 by jlr19
PenkethBoy 2068 Posted May 10, 2019 Posted May 10, 2019 An idea - guess Go through each of you libraries and toggle the RTM off - exit the page wait 5 secs then go back and re enable RTM This will save the xml file for the library - i had an issue with one of the betas where the xml was not updated to reflect new (added) settings till i did this - although it was not related to RTM - it might help
CharleyVarrick 284 Posted May 10, 2019 Author Posted May 10, 2019 2) Kodi, with help from Emby for Kodi, on two win10 machines Please note continous scan behavior was observed without any Kodi device running
CBers 7573 Posted May 10, 2019 Posted May 10, 2019 @@jlr19 Looks like you posted at the same time as @@PenkethBoy - did you see his post ? Also, have you checked your hardware, in case there is a failing drive ?
CharleyVarrick 284 Posted May 10, 2019 Author Posted May 10, 2019 An idea - guess Go through each of you libraries and toggle the RTM off - exit the page wait 5 secs then go back and re enable RTM This will save the xml file for the library - i had an issue with one of the betas where the xml was not updated to reflect new (added) settings till i did this - although it was not related to RTM - it might help I did just that, to no avail
CharleyVarrick 284 Posted May 10, 2019 Author Posted May 10, 2019 @@jlr19 Looks like you posted at the same time as @@PenkethBoy - did you see his post ? Also, have you checked your hardware, in case there is a failing drive ? Yes and yes. Stablebit scanner reports all drives nominal
CBers 7573 Posted May 10, 2019 Posted May 10, 2019 Yes and yes. Stablebit scanner reports all drives nominal Ah, a DrivePool user I wonder if @@PenkethBoy or @@cayars have any input.
PenkethBoy 2068 Posted May 10, 2019 Posted May 10, 2019 Doubt its DP as i would see the same issue and i dont 1
CharleyVarrick 284 Posted May 10, 2019 Author Posted May 10, 2019 (edited) There seems to be a ton of errors in my Emby log, but I have no idea how to interpret them. Recent log attached, in case it could help... embyserver.txt Edited May 10, 2019 by jlr19
PenkethBoy 2068 Posted May 10, 2019 Posted May 10, 2019 Yes loads of errors to do with Moviedb lookup Does this path exist even if the file does not? Could not find a part of the path 'C:\Users\jlr\AppData\Roaming\Emby-Server\programdata\cache\tmdb-movies2\394144\all-en.json'
