_Seb_ 1 Posted May 2, 2019 Posted May 2, 2019 Hi! I use Emby Version 4.1.1.0 running on a Synology Diskstation. I'm streaming through Google Chrome. Today I saw that the Subtitles for normal is located at the top of the screen. When I change to smaller or larger they are placed at the bottom of the screen (where I prefer them to be). As soon as I change back to normal size they go at the top again. I'm attaching a couple of screenshots. Any ideas? Thanks.
Luke 42221 Posted May 2, 2019 Posted May 2, 2019 Hi, this is actually due to a defect in Chrome 74+. As soon as any custom styles are applied, it puts the subtitles at the top for some reason. With default styles, it stays at the bottom. We are monitoring the Chrome betas to see if it gets resolved. Thanks. 1
Happy2Play 9806 Posted June 5, 2019 Posted June 5, 2019 Can everyone verify Chrome 75 has resolved this issue.
Solution Wondertje 10 Posted June 5, 2019 Solution Posted June 5, 2019 It appears to work for me for now, I just upgraded to Chrome 75. 1
Dusty_Quill 0 Posted June 16, 2019 Posted June 16, 2019 Had the same issue, came here for a solution, had Chrome v74 upgraded to v75 and now the problem is solved
