Kolomona 0 Posted May 17, 2019 Author Posted May 17, 2019 Are there any mitigation options available?I can get the server to run just fine with the following command: $ sudo /opt/emby-server/bin/emby-server -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb I just can't get the service to start, so I have to keep my terminal open
Luke 42246 Posted May 18, 2019 Posted May 18, 2019 That's actually the best workaround i've seen so far. The problem is we have never reproduced this ourselves, it's only been about five users and we believe the issue is tied to the .net core ticket I linked to above.
Kolomona 0 Posted May 19, 2019 Author Posted May 19, 2019 HA! I believe I fixed it! I was on the right track when I set my local to en_US.UTF-8 But for some reason I didn't set the LANG env variable I got the idea for this fix from this URL https://github.com/dotnet/corefx/issues/37630 TLDR: Make sure LANG is set to en_US.UTF-8 (If you have a different local, make sure it's not set to C.UTF-8) $ locale LANG=C.UTF-8 LANGUAGE= LC_CTYPE="en_US.UTF-8" LC_NUMERIC="en_US.UTF-8" LC_TIME="en_US.UTF-8" LC_COLLATE="en_US.UTF-8" LC_MONETARY="en_US.UTF-8" LC_MESSAGES="en_US.UTF-8" LC_PAPER="en_US.UTF-8" LC_NAME="en_US.UTF-8" LC_ADDRESS="en_US.UTF-8" LC_TELEPHONE="en_US.UTF-8" LC_MEASUREMENT="en_US.UTF-8" LC_IDENTIFICATION="en_US.UTF-8" LC_ALL=en_US.UTF-8 Notice that the LANG=C.UTF-8 NOT en_US.UTF-8 So I did the following: $ sudo update-locale LANG=en_US.UTF-8 $ sudo reboot $ locale LANG=en_US.UTF-8 LANGUAGE= LC_CTYPE="en_US.UTF-8" LC_NUMERIC="en_US.UTF-8" LC_TIME="en_US.UTF-8" LC_COLLATE="en_US.UTF-8" LC_MONETARY="en_US.UTF-8" LC_MESSAGES="en_US.UTF-8" LC_PAPER="en_US.UTF-8" LC_NAME="en_US.UTF-8" LC_ADDRESS="en_US.UTF-8" LC_TELEPHONE="en_US.UTF-8" LC_MEASUREMENT="en_US.UTF-8" LC_IDENTIFICATION="en_US.UTF-8" LC_ALL=en_US.UTF-8 ~$ sudo service emby-server status ● emby-server.service - Emby Server is a personal media server with apps on just about every device. Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: active (running) since Sun 2019-05-19 21:58:25 UTC; 43s ago Main PID: 908 (EmbyServer) Tasks: 15 (limit: 2361) CGroup: /system.slice/emby-server.service └─908 /opt/emby-server/system/EmbyServer -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-serv May 19 21:58:33 KmCreations emby-server[908]: Info App: SyncRepository Initialize write lock taken May 19 21:58:33 KmCreations emby-server[908]: Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.0149967 seconds May 19 21:58:33 KmCreations emby-server[908]: Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint May 19 21:58:33 KmCreations emby-server[908]: Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0055851 seconds May 19 21:58:33 KmCreations emby-server[908]: Info App: Starting entry point EmbyServer.Windows.LoopUtilEntryPoint May 19 21:58:33 KmCreations emby-server[908]: Info App: Entry point completed: EmbyServer.Windows.LoopUtilEntryPoint. Duration: 0.0004747 seconds May 19 21:58:33 KmCreations emby-server[908]: Info App: All entry points have started May 19 21:58:33 KmCreations emby-server[908]: Application started. Press Ctrl+C to shut down. May 19 21:58:33 KmCreations emby-server[908]: Hosting environment: Production May 19 21:58:33 KmCreations emby-server[908]: Content root path: /opt/emby-server/system/ SUCCESS! The server loaded on reboot and appears to functioning. It also seems to have fixed my zero byte log files issue! $ ls -al /var/lib/emby/logs/ total 180 drwxr-xr-x 2 emby emby 4096 May 19 21:59 . drwxr-xr-x 10 emby emby 4096 May 7 15:18 .. -rw-r--r-- 1 emby emby 49271 May 19 22:00 embyserver.txt -rw-r--r-- 1 emby emby 117113 May 19 21:58 hardware_detection-63693899913.txt I don't have time right now to fully test. If I run into any other issues I'll post them Thanks @@Luke for trying to help me with this. Your questioning me about my locale was key to figuring it out.
