Biomorph 6 Posted May 1, 2019 Posted May 1, 2019 After the update from 4.0.3.0 to 4.1.0.26 and also with 4.1.1.0 I too am no longer seeing hardware acceleration options. I have attached hardware detections logs from 4.0.3.0 and 4.1.1.0. Post 4.0.txt 4.0.txt
softworkz 5130 Posted May 1, 2019 Posted May 1, 2019 @@Biomorph - It would be better if you had created a new thread This is creating too much much confusion - at least for myself... ;-) What OS do you have? Does it support DirectX 11.1?
Biomorph 6 Posted May 1, 2019 Author Posted May 1, 2019 Sorry, being that this thread existed and had been viewd I thought best to carry on here. Running Win 7 Pro so I believe supports DX11 but 11.1 I'm not so sure about.
softworkz 5130 Posted May 1, 2019 Posted May 1, 2019 @@Biomorph - Nevermind, I've split this into a separate conversation. Could you please run 'dxdiag' (Win-Key + R, then enter 'dxdiag' and press enter)
Biomorph 6 Posted May 2, 2019 Author Posted May 2, 2019 Have attached shots of what I gather are the relevant tabs.
Skynet92 5 Posted May 2, 2019 Posted May 2, 2019 Hello, look my last post. https://emby.media/community/index.php?/topic/72920-latest-emby-update-41026-issue/&do=findComment&comment=737055
Biomorph 6 Posted May 2, 2019 Author Posted May 2, 2019 I have Googled 20190430-19af948 x64 and downloaded the file found, so I just replace ffdetect, ffmpeg and ffprobe in the system folder with these newer files?
Skynet92 5 Posted May 2, 2019 Posted May 2, 2019 I have Googled 20190430-19af948 x64 and downloaded the file found, so I just replace ffdetect, ffmpeg and ffprobe in the system folder with these newer files? Yes, but save the old FFmpeg before. Reboot Emby and try.
Biomorph 6 Posted May 2, 2019 Author Posted May 2, 2019 Updated to 4.1.1.0, copied files to system folder, rebooted and still nothing listed under preferred hardware decoders.
Skynet92 5 Posted May 2, 2019 Posted May 2, 2019 Updated to 4.1.1.0, copied files to system folder, rebooted and still nothing listed under preferred hardware decoders. You're Emby premiere right ?
Skynet92 5 Posted May 2, 2019 Posted May 2, 2019 Radeon HD5450 Unfortunately, I don't know much about AMD card. For hardware acceleration Nvidia is more convenient.
Biomorph 6 Posted May 2, 2019 Author Posted May 2, 2019 Have a user currently watching, is transcoding via software and have also noticed that the throttling doesn't appear to be occuring. Will have to revert back to 4.0.3.0 and hope a resolution comes about in a future release.
softworkz 5130 Posted May 2, 2019 Posted May 2, 2019 @@Biomorph We will fix this on our side. At some point we are checking whether DX11 is available while we should actually check for DX11.1 instead. But until this is done, there is one thing that you can try: There exists a platform update for Win 7 that adds "partial" support for DX11.1 - but that partial support might be sufficient. Information : https://docs.microsoft.com/en-us/windows/desktop/direct3darticles/platform-update-for-windows-7 Download: https://support.microsoft.com/en-us/help/2670838/platform-update-for-windows-7-sp1-and-windows-server-2008-r2-sp1 DISCLAIMER: There might be some risks installing that update. Please read through all information before making a decision. If you decide to try: Create a system restore point Better switch to onboard graphics before updating (if available)Connect your monitor to onboard graphics, restart, install latest drivers for onboard graphics Create another system restore point Install the platform update Connect your monitor back to the Radeon
Biomorph 6 Posted May 5, 2019 Author Posted May 5, 2019 Thanks for the info @@softworkz. As the physical server is also used to run a client taking these steps would probably require more downtime then the kids will allow! Just knowing that there is a fix coming in the future is great to hear and I'll sit tight on 4.0 till then. Also a big thank you for your contribution overall to the development of Emby.
Biomorph 6 Posted July 27, 2019 Author Posted July 27, 2019 I have installed the new 4.2 release and again there is no listing under preferred hardware decoders, is the fix not yet implemented or might there be another issue?
softworkz 5130 Posted September 2, 2019 Posted September 2, 2019 @@Biomorph - Thanks for your patience. This should be fixed in the next beta.
Biomorph 6 Posted September 3, 2019 Author Posted September 3, 2019 Thankyou for the info and another big thankyou for your efforts.
