w84no1 27 Posted May 17, 2014 Posted May 17, 2014 I promised to do this a while ago, so here is a video of XBMB3C running on my PI. http://youtu.be/CMMxyOKd8_0 2
xnappo 1611 Posted May 17, 2014 Posted May 17, 2014 Yeah.. So pretty much unusable Thanks for the video though. I have heard it runs much better on Ouya/XIOS - would love to see a video of that. xnappo
w84no1 27 Posted May 18, 2014 Author Posted May 18, 2014 Yeah, I use the PIs in the kids room ;-) Yes it is a whole lot better on the Ouya, I will try to video the Ouya.
CBers 7554 Posted May 18, 2014 Posted May 18, 2014 (edited) There was this video of "Mediabrowser3 android client sending video to XBMC" which I believe was running on a Raspberry Post, that was posted by @@scalda a while back. http://youtu.be/Cxr7AMnMXXc Edited May 18, 2014 by CBers
Spaceboy 2573 Posted May 18, 2014 Posted May 18, 2014 Shame, I was hoping the improvements you posted about a few weeks ago might have made some difference. It does make xbmc a playable client using the ios iPhone ipad and android apps so it's not all bad! Still get the boblight working! Sent from my iPad using Tapatalk
xnappo 1611 Posted May 18, 2014 Posted May 18, 2014 Yeah, Pi is never going to run fast - Python just runs too slow on it. XIOS and Ouya are cheap enough though xnappo
w84no1 27 Posted May 18, 2014 Author Posted May 18, 2014 Yeah, Pi is never going to run fast - Python just runs too slow on it. XIOS and Ouya are cheap enough though xnappo I have the Ouya and it is just OK. I am about to drop XBMC all together and just get a Roku3 to use as my MB3 client.
Spaceboy 2573 Posted May 18, 2014 Posted May 18, 2014 I've got a roku xs 2 I think. I like it Sent from my iPad using Tapatalk
xnappo 1611 Posted May 19, 2014 Posted May 19, 2014 Off topic - but does Roku mean transcoding? xnappo
w84no1 27 Posted May 19, 2014 Author Posted May 19, 2014 (edited) Off topic - but does Roku mean transcoding? xnappo Depends on file type/encoding. I found this http://sdkdocs.roku.com/display/sdkdoc/Encoding+Guide#EncodingGuide-25SupportedVideoFormats Edited May 19, 2014 by w84no1
Bobba86 34 Posted May 20, 2014 Posted May 20, 2014 I've got a Pi (Type , Running XBMC & XBMB3C - and for me it runs OK e.g. it is usable. - clean install of XBian, - Updated to Gotham. - Video Running in 720p - Did not configure anything in the XBMC library. - Installed XBMB3C, addon and the Arctic Skin (from the XBMB3C repo). - Within XBMB3C addon I enabled the JSON switch.. and also disabled Fanart Backgrounds. The Arctic skin took some customising to find out the best views for the Pi... but overall the skin it seems pretty light. I am able to navigate through Movies TV shows with no problem. the best view I found is the Thumbnail View. When opening a video it can take a little while (up to 20 seconds) before the stream starts. So using the remote is fine, but where I find the Pi works best is as a device to stream to either using the Android or the Web client. Find the content you want to play on your Phone or Tablet then send it to your Pi.
Spaceboy 2573 Posted May 20, 2014 Posted May 20, 2014 (edited) Agreed, but then a chromecast is only £30 and much less hassle Actually that's wrong, with xbmc you could use all the non video stuff, spotify ran ok, I think Iplayer worked, you can use xbmc addons such as the boblight led setup. Sent from my iPad using Tapatalk Edited May 20, 2014 by Spaceboy
xnappo 1611 Posted May 20, 2014 Posted May 20, 2014 I guess I have been over at AVSForum for too long - for me transcoding is a show-stopper. xnappo
w84no1 27 Posted May 20, 2014 Author Posted May 20, 2014 I guess I have been over at AVSForum for too long - for me transcoding is a show-stopper. xnappo I don't mind transcoding as long as it is on the kids TVs and not mine 1
Spaceboy 2573 Posted May 20, 2014 Posted May 20, 2014 Ditto, you have to transcode for mobile anyway but I wouldnt recommend chromecast or pi for a main tv Sent from my iPad using Tapatalk 1
xnappo 1611 Posted May 21, 2014 Posted May 21, 2014 Sounds like we are on the same page NUCs are really cheap now! xnappo 1
Spaceboy 2573 Posted May 21, 2014 Posted May 21, 2014 I like my nuc. Does full htpc duties and emulates up to psx games. I have win8 installed on it but I could be persuaded to try a Linux one when a mb3 client is developed. Sent from my iPad using Tapatalk
