wayloncovil 2 Posted May 1, 2019 Posted May 1, 2019 A few weeks ago I rebuilt my Emby server (I have a simple install and it wasn't too hard.) Before doing so, I re-scanned my channels on my HD Homerun. I noticed that the channel names changed after the rescan. I also noticed in the recordings that I scheduled in Emby that the identifier appears to be the names associated with the channels. For example, when I look at my recording for Wild Kratts, it's set to record channel OPB only. So, 2 questions... If the names associated with the channel updates, will my scheduled recordings in Emby get messed up somehow? And, I have a few channels scheduled to update with Repack 3 (June 21st). Will rescanning after the repack affect my scheduled recordings? Thanks!
Luke 42239 Posted May 3, 2019 Posted May 3, 2019 Will rescanning after the repack affect my scheduled recordings? Hi, it depends on how much the channel data changes. If the channel list coming from your HDHR changes significantly, then yes you may need to re-schedule your recordings. Usually this won't be needed though. Please let us know if this helps and how this goes. Thanks.
