Dysan 2 Posted April 30, 2019 Posted April 30, 2019 Because its almost time to renew my certificate, I did that trough WACS, what completed sucessfully, i have 2 files a emby.domain.nl-chain.pem , emby.domain.nl-key.pem i have to create a pfx file with the following command: pkcs12 -export -out c:/ssl/emby.pfx -inkey c:/ssl/emby.domain.nl-key.pem -in c:/ssl/emby.domain.nl-chain.pem -certfile c:/ssl/emby.domain.nl-chain.pem and enter the password twice. when pointing Emby to the new certificate i get an error in my log, and https: is not reachable: C:\ssl>openssl pkcs12 -info -in c:\ssl\emby3.pfx Enter Import Password: MAC: sha1, Iteration 2048 MAC length: 20, salt length: 8 PKCS7 Encrypted data: pbeWithSHA1And40BitRC2-CBC, Iteration 2048 Certificate bag Bag Attributes localKeyID: 70 F9 62 F3 78 67 92 51 82 D7 B9 A3 8B 44 89 75 35 B3 7F DE subject=CN = emby.domain.nl issuer=C = US, O = Let's Encrypt, CN = Let's Encrypt Authority X3 -----BEGIN CERTIFICATE----- blablabla PKCS7 Data Shrouded Keybag: pbeWithSHA1And3-KeyTripleDES-CBC, Iteration 2048 Bag Attributes localKeyID: 70 F9 62 F3 78 67 92 51 82 D7 B9 A3 8B 44 89 75 35 B3 7F DE Key Attributes: <No Attributes> Enter PEM pass phrase: Verifying - Enter PEM pass phrase: -----BEGIN ENCRYPTED PRIVATE KEY----- blablabla -----END ENCRYPTED PRIVATE KEY----- And a test: C:\ssl>openssl s_client -showcerts -connect emby.domain.nl:8920 CONNECTED(000000F8) write:errno=0 --- no peer certificate available --- No client certificate CA names sent --- SSL handshake has read 0 bytes and written 315 bytes Verification: OK --- New, (NONE), Cipher is (NONE) Secure Renegotiation IS NOT supported Compression: NONE Expansion: NONE No ALPN negotiated Early data was not sent Verify return code: 0 (ok) --- But the emby log shows: 2019-04-30 23:12:31.010 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 4.1.1.0 Command line: C:\Users\embyserver\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///C:/Users/embyserver/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 6 Program data path: C:\Users\embyserver\AppData\Roaming\Emby-Server Application directory: C:\Users\embyserver\AppData\Roaming\Emby-Server\system System.ComponentModel.Win32Exception: System.ComponentModel.Win32Exception (0x8009030D): The credentials supplied to the package were not recognized at System.Net.SSPIWrapper.AcquireCredentialsHandle(SSPIInterface secModule, String package, CredentialUse intent, SCHANNEL_CRED scc) at System.Net.Security.SslStreamPal.AcquireCredentialsHandle(CredentialUse credUsage, SCHANNEL_CRED secureCredential) at System.Net.Security.SslStreamPal.AcquireCredentialsHandle(X509Certificate certificate, SslProtocols protocols, EncryptionPolicy policy, Boolean isServer) at System.Net.Security.SecureChannel.AcquireServerCredentials(Byte[]& thumbPrint, Byte[] clientHello) at System.Net.Security.SecureChannel.GenerateToken(Byte[] input, Int32 offset, Int32 count, Byte[]& output) at System.Net.Security.SecureChannel.NextMessage(Byte[] incoming, Int32 offset, Int32 count) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult) at System.Net.Security.SslStream.BeginAuthenticateAsServer(SslServerAuthenticationOptions sslServerAuthenticationOptions, CancellationToken cancellationToken, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c.<AuthenticateAsServerAsync>b__50_1(X509Certificate arg1, Boolean arg2, SslProtocols arg3, AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl[TArg1,TArg2,TArg3](Func`6 beginMethod, Func`2 endFunction, Action`1 endAction, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync[TArg1,TArg2,TArg3](Func`6 beginMethod, Action`1 endMethod, TArg1 arg1, TArg2 arg2, TArg3 arg3, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.Init() at SocketHttpListener.Net.HttpEndPointListener.ProcessAccept(SocketAsyncEventArgs args) Source: System.Net.Security TargetSite: System.Net.Security.SafeFreeCredentials AcquireCredentialsHandle(System.Net.SSPIInterface, System.String, CredentialUse, SCHANNEL_CRED) I'm pretty lost at this point what the real issue is.
Dysan 2 Posted April 30, 2019 Author Posted April 30, 2019 Ok, import it in microsoft, then export it again with the password needed in Emby seems to fix it? what is the most correct guide on this issue ?
Luke 42219 Posted May 3, 2019 Posted May 3, 2019 Ok, import it in microsoft What exactly did you import it into, windows?
Luke 42219 Posted May 12, 2019 Posted May 12, 2019 I did read somewhere about pfx password requirements in .net core 2.0, which is what we're built on. I'll have to see if i can find that. Thanks.
