Okeur75 7 Posted April 30, 2019 Posted April 30, 2019 (edited) Hello guys, Yes another apache reverse proxy tuto but I'm a bit stuck ! I found a vhost config that works in my case : <VirtualHost *:80> ServerName my.website Redirect permanent /emby https://my.website/emby </VirtualHost> <VirtualHost *:443> ServerName my.website ErrorLog ${APACHE_LOG_DIR}/emby-error_log LogFormat "%t \"%r\" %>s" common CustomLog ${APACHE_LOG_DIR}/emby-access_log common RewriteEngine on RewriteRule ^/emby$ /emby/ [R] <proxy *> AddDefaultCharset off Order Allow,Deny Allow from all </proxy> ProxyRequests Off ProxyPreserveHost On <Location /emby> ProxyPass http://localhost:8096 ProxyPassReverse http://localhost:8096 </Location> <Location /emby/emby> ProxyPass ws://localhost:8096/emby ProxyPassReverse ws://localhost:8096/emby </Location> </VirtualHost> If I only enable this vhost it's working. But ! I also have transmission running with the following configuration: <VirtualHost *:443> ServerName my.website ServerAlias www.my.website Redirect permanent /transmission https://my.website/transmission RewriteEngine on RewriteRule /transmission[/]?$ /transmission/web/ [R=permanent] ProxyRequests On ProxyPreserveHost Off <Proxy *> Order allow,deny Allow from all </Proxy> ProxyPass /transmission http://127.0.0.1:9091/transmission ProxyPassReverse /transmission http://127.0.0.1:9091/transmission </Virtualhost> <VirtualHost *:80> ServerName my.website ServerAlias www.my.website Redirect permanent /transmission https://my.website/transmission </Virtualhost> If I enable emby first (by renaming the file 01-emby and 03-transmission) : emby is working but transmission is not. If I enable transmission first (01-transmission and 03-emby) : transmission is working and emby is not with the following error message : You don't have permission to access /emby on this server. So I guess there is some issue with the rewrite rule. In emby dashboard I selected the "Secure connection mode" parameter to "Handled by reverse proxy". For info https://my.website:8920/emby is working. I'm not really familiar with Apache so I may have missed something obvious. Thanks for your help guys ! Edited May 2, 2019 by Okeur75
Luke 42246 Posted April 30, 2019 Posted April 30, 2019 @@pir8radio are you familiar with transmission?
pir8radio 1313 Posted April 30, 2019 Posted April 30, 2019 (edited) @@pir8radio are you familiar with transmission? Yea, but I think his issue is config related.. I assume when you say you use transmission you mean the web interface to the torrent client? Post your whole apache config with both transmission and emby sections in that you want... and lets take a look at it. switch to nginx and we can get you up in no time! :-) Edited April 30, 2019 by pir8radio
Okeur75 7 Posted May 1, 2019 Author Posted May 1, 2019 (edited) Thanks @@Luke Thanks @@pir8radio Yes it's totally configuration related. Emby is working fine otherwise. I know it's a bit bordeline for Emby's support but this is the only forum with strong knowledge about emby and its related vhost configuration. Yes I meant the web interface of Transmission What else do you need apart from the vhost configuration ? I have 2 other vhost that are not impacted by any change on emby or transmission vhost configuration, and the rest of the apache configuration is just ssl and includes statement in the main apache.conf file. I can copy paste everything if you need it but I'd surprised it helps. I'm not really keen to switch to Nginx, not that I have specific needs for Apache, but I would like first to understand how to do something and not switch to a whole new solution just because I don't understand. I'm pretty sure few lines need to be modified to make this work Edit : also the goal design if it helps http://my.website/nextcloud -> https://my.website/nextcloud (working) http://my.website/zabbix -> https://my.website/zabbix (working) http://my.website/transmission -> https://my.website/transmission (which is also a redirect to http://127.0.0.1:9091/transmission) Working if enabled before Emby http://my.website/emby -> https://my.website/transmission (which is also a redirect to http://127.0.0.1:8096) Working if enabled before Transmission http://my.website/ -> you don't have the permission to access / on this server (as expected) https://my.website/ -> you don't have the permission to access / on this server (as expected) Edited May 1, 2019 by Okeur75
Solution Okeur75 7 Posted May 2, 2019 Author Solution Posted May 2, 2019 Hello guys, I found the solution and wanted to share if someone needs it. The issue was actually I have only one domain name and no subdomain. So there is no real vhost running on my server, just multiple website in different folders or as Emby, managed by their own web server. The issue was 2 vhost files both catching the same domain name, hence only the first one was catched and the second one ignore. That's why Emby was working when enabled first, and Transmission no working, or the opposite when Transmission was enabled first. To sum up, here is the config file which is working in my case : Transmission torrent client running on 9091 + Emby running on 8920 <VirtualHost *:80> ServerName yoann.host ServerAlias www.yoann.host Redirect permanent /transmission https://yoann.host/transmission Redirect permanent /emby https://yoann.host/emby </Virtualhost> <VirtualHost *:443> ServerName yoann.host ServerAlias www.yoann.host Redirect permanent /transmission https://yoann.host/transmission Redirect permanent /emby https://yoann.host/emby ErrorLog ${APACHE_LOG_DIR}/transmission_emby_error_log LogFormat "%t \"%r\" %>s" common CustomLog ${APACHE_LOG_DIR}/transmission_emby_access_log common RewriteEngine on RewriteRule /transmission[/]?$ /transmission/web/ [R] RewriteRule ^/emby$ /emby/ [R] ProxyRequests On ProxyPreserveHost Off <Proxy *> Order allow,deny Allow from all </Proxy> <location /transmission> ProxyPass http://127.0.0.1:9091/transmission ProxyPassReverse http://127.0.0.1:9091/transmission </location> <location /emby> ProxyPass http://127.0.0.1:8096/emby ProxyPassReverse http://127.0.0.1:8096/emby </location> <location /embywebsocket> ProxyPass http://127.0.0.1:8096/embywebsocket ProxyPassReverse http://127.0.0.1:8096/embywebsocket </location> </Virtualhost> Glad if it helps someone and thanks to both of you guys for taking a look. 1
pir8radio 1313 Posted May 3, 2019 Posted May 3, 2019 Hello guys, I found the solution and wanted to share if someone needs it. The issue was actually I have only one domain name and no subdomain. So there is no real vhost running on my server, just multiple website in different folders or as Emby, managed by their own web server. The issue was 2 vhost files both catching the same domain name, hence only the first one was catched and the second one ignore. That's why Emby was working when enabled first, and Transmission no working, or the opposite when Transmission was enabled first. To sum up, here is the config file which is working in my case : Transmission torrent client running on 9091 + Emby running on 8920 Glad if it helps someone and thanks to both of you guys for taking a look. I think you might find some things not working correctly with a sub directory, vs using a sub domain emby.domain.com, transmission.domain.com But let us know how it goes.. :-)
