Flip_5 1 Posted April 30, 2019 Posted April 30, 2019 I am using Emby on my QNAP TVS-1282, with all video files being hosted on the same NAS device. It has been working great until recently. I added some new movies to my Movie library, and after adding them, they weren't showing up. Seems like they weren't being scanned into the library. Prior to this, I had upgraded Emby to the latest version, and I have noticed a few other posts having similar issues. After dealing with other strange issues in my QNAP (unable to install/reinstall/remove apps, among other things) I reinstalled QTS and reset the NAS. I reinstalled Emby and strangely, all my settings from the original install were retained. Knowing this shouldn't be the case, I uninstalled and reinstalled Emby. At this point I had to setup Emby from scratch, create new libraries, etc. I have 4 libraries: Intros, Movies, Theater, and TV Shows. Once setup I went to scan all libraries. Intros, Theater, and TV Shows all populated correctly, however, Movies is now blank. What started out as not scanning new movies has turned into not having any movies in the library. Attached is the latest log file, I did a rotate log file, restart emby server, and scan library using the "..." icon from Movies thumbnail on the libraries page. embyserver.txt
Luke 42241 Posted April 30, 2019 Posted April 30, 2019 Hi there, what folder have you added to your Movies library? What about your Theater library?
Flip_5 1 Posted April 30, 2019 Author Posted April 30, 2019 Intros: /share/CACHEDEV1_DATA/Multimedia/Intros Movies : /share/CACHEDEV1_DATA/Multimedia/Movies Theater: /share/CACHEDEV1_DATA/Multimedia/Theater TV Shows: /share/CACHEDEV1_DATA/Multimedia/TVShows Intros is set as "Home Videos" Movies is set as "Movies" Theater is set as "Home Videos"
Flip_5 1 Posted May 1, 2019 Author Posted May 1, 2019 As a test, I installed Emby server on my laptop and set up the movie library and all movies scanned in and work as expected, so nothing's wrong with the folder or files.
Flip_5 1 Posted May 2, 2019 Author Posted May 2, 2019 Can anyone point me in the right direction to fix this? I've uninstalled and reinstalled Emby multiple times, my QNAP did a firmware update (including kernel), and still not showing any movies in the Movie library.
Luke 42241 Posted May 2, 2019 Posted May 2, 2019 Hi there, can you please run a library scan and then attach the emby server log? Thanks !
Flip_5 1 Posted May 2, 2019 Author Posted May 2, 2019 Hi there, can you please run a library scan and then attach the emby server log? Thanks ! embyserver.txt
mrfragger 39 Posted May 2, 2019 Posted May 2, 2019 Seems like this part of your log might be relevant. Perhaps create a new folder and share and just move your movies there. Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/share/CACHEDEV1_DATA/Multimedia/Movies/Aut�mata (2014)'. File name: '/share/CACHEDEV1_DATA/Multimedia/Movies/Aut�mata (2014)' Source: TargetSite: No Stack Trace Available 2019-04-30 12:21:15.500 Info LibraryMonitor: Stopping directory watching for path /share/CACHEDEV1_DATA/Multimedia/Movies 2019-04-30 12:21:15.512 Info LibraryMonitor: Watching directory /share/CACHEDEV1_DATA/Multimedia/TVShows 2019-04-30 12:21:15.549 Info LibraryMonitor: Watching directory
Solution Flip_5 1 Posted May 2, 2019 Author Solution Posted May 2, 2019 So it seems somewhere along the line, Emby became more sensitive to special characters. Something that scanned before, would not scan now and apparently cause it to not scan the library at all. I did notice this in the logs before, but also saw similar errors in the TV Shows library, so I dismissed it as the cause. Once I renamed the one movie folder Autómata (2014) to Automata (2014) everything started scanning. It also had added an empty folder Aut.@_thumb which I also deleted. I assume this .@_thumb folder should have been placed within the directory, but when it reached the special character it didn't know what to do. Hopefully this helps pinpoint the cause and maybe help others that are having the same problem. Luke, thanks for pointing me in the right direction.
Flip_5 1 Posted May 2, 2019 Author Posted May 2, 2019 Seems like this part of your log might be relevant. Perhaps create a new folder and share and just move your movies there. Application directory: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/share/CACHEDEV1_DATA/Multimedia/Movies/Aut�mata (2014)'. File name: '/share/CACHEDEV1_DATA/Multimedia/Movies/Aut�mata (2014)' Source: TargetSite: No Stack Trace Available 2019-04-30 12:21:15.500 Info LibraryMonitor: Stopping directory watching for path /share/CACHEDEV1_DATA/Multimedia/Movies 2019-04-30 12:21:15.512 Info LibraryMonitor: Watching directory /share/CACHEDEV1_DATA/Multimedia/TVShows 2019-04-30 12:21:15.549 Info LibraryMonitor: Watching directory Thanks, I had seen this and corrected it, that was it. You replied before I posted my last message.
