peppeantonini 0 Posted October 17, 2019 Posted October 17, 2019 I must have misread the hurry. For security I removed Emby and reinstalled. Do I try to rename SQLitePCLRaw.provider.sqlite3.dll.config to EmbyServer.dll.config (in the /share/MD0_DATA/.qpkg/EmbyServer/system folder)?
Luke 42241 Posted October 17, 2019 Posted October 17, 2019 Yes please try that, and if that doesn't work, then please try the instructions in post #39. Thanks.
peppeantonini 0 Posted October 17, 2019 Posted October 17, 2019 After or inside the node? (like the dll.config)? I have prepared 2 possible files: which would be the correct one? If that doesn't work, then please open this file: EmbyServer.exe.config and add this after the configuration node: <dllmap dll="sqlite3" target="lib/libsqlite3.so" os="linux"/> EmbyServer.exe.zip
peppeantonini 0 Posted October 17, 2019 Posted October 17, 2019 step 1 I installed Emby I tried to open the web interface on port 8096, but without an answer step 2 I interrupted Emby from the QNAP app center I renamed the file /share/MD0_DATA/.qpkg/EmbyServer/system/SQLitePCLRaw.provider.sqlite3.dll.config in /share/MD0_DATA/.qpkg/EmbyServer/system/EmbyServer.dll.config I started Emby from the QNAP app center I tried to open the web interface on port 8096, but without an answer step 3 I interrupted Emby from the QNAP app center I started Emby from the QNAP app center I tried to open the web interface on port 8096, but without an answer step 4 I interrupted Emby from the QNAP app center I edited the EmbyServer.exe.config file, adding <dllmap dll = "sqlite3" target = "lib / libsqlite3.so" os = "linux" /> after the node I started Emby from the QNAP app center I tried to open the web interface on port 8096: reply the wizard starts, I choose the language and crash: the web interface doesn't respond steps.zip
Luke 42241 Posted October 17, 2019 Posted October 17, 2019 Fantastic, thank you! Step 4 works and @@alucryd can incorporate those changes into the next release. Thanks for helping out.
peppeantonini 0 Posted October 17, 2019 Posted October 17, 2019 Now the web interface doesn't respond. I'll try again tomorrow... Fantastic, thank you! Step 4 works and @@alucryd can incorporate those changes into the next release. Thanks for helping out.
Luke 42241 Posted October 23, 2019 Posted October 23, 2019 Now the web interface doesn't respond. I'll try again tomorrow... Did you try rebooting the NAS?
peppeantonini 0 Posted October 24, 2019 Posted October 24, 2019 Yes, I tried embyserver-63707519505.txt
Luke 42241 Posted October 24, 2019 Posted October 24, 2019 Ok, so now we've gone back in a circle as you're back on the 4.2.1 stable release with the initial problem reported in this topic.
Luke 42241 Posted October 29, 2019 Posted October 29, 2019 Please try the latest beta server install. It has the sqlite fix we've been discussing here. Thanks.
peppeantonini 0 Posted October 30, 2019 Posted October 30, 2019 I tried: the configuration wizard starts and freeze immediately embyserver.txt hardware_detection-63708023794.txt
Luke 42241 Posted October 30, 2019 Posted October 30, 2019 Does the browser debug console show any errors?
peppeantonini 0 Posted October 30, 2019 Posted October 30, 2019 I restarted the nas and this time it stopped after choosing the language. 192.168.2.6-1572450537476.log embyserver.txt hardware_detection-63708050561.txt
roux 0 Posted April 13, 2020 Posted April 13, 2020 Hi, What happened with this thread?? I am having the same exact problem. I am able to make it through config after many tries, but am unable to log in w/out crashing.
Luke 42241 Posted April 13, 2020 Posted April 13, 2020 Hi, What happened with this thread?? I am having the same exact problem. I am able to make it through config after many tries, but am unable to log in w/out crashing. Hi, what model do you have?
peppeantonini 0 Posted April 14, 2020 Posted April 14, 2020 Hi, What happened with this thread?? I am having the same exact problem. I am able to make it through config after many tries, but am unable to log in w/out crashing. I have never solved it, since the application crashed all the time. In the meantime I switched to an X86 nas, where the application runs very well.
Luke 42241 Posted September 1, 2020 Posted September 1, 2020 Is anyone willing to provide SSH access to their NAS so that we can debug on your machine directly? That may allow us to solve this quickly. If you're interested in helping out please send me a PM. Thanks !
