BillOatman 597 Posted April 29, 2019 Posted April 29, 2019 (edited) Hi. What I am thinking of is hooking into the live tv guide and adding a context menu when you click on a show in the guide. Right now for example you see a record button if the show is in the future. I would like to add another button and action called "Remind" that would have Emby change to that channel at the start of the show. So the work flow would be: 1) Call up the live tv guide and advance into the future to a show you want to watch. 2) Select a show and the context menu opens. Example: show XYZ that starts at 20:00 on channel 123. 3) Press the Remind button. 4) At 19:59:50 a messagebox opens saying the channel is about to change. 5) At 19:59:55 Emby changes the channel to channel 123. I know it may be a long shot since the bulk of the guide logic seems to be on the client devices, but is there a plugin interface I could use? Edited April 29, 2019 by BillOatman
Solution Luke 42255 Posted April 29, 2019 Solution Posted April 29, 2019 A plugin could get guide data but you won't be able to change the UI. 1
