hazhanglei 3 Posted April 29, 2019 Posted April 29, 2019 Like the above two pictures, you can display when you select a folder. When I select the SHOWS, the red circle in the second picture will not be displayed in the SHOWS. The folder flag displayed in the upper left corner will not be displayed in the shows.
Luke 42219 Posted April 29, 2019 Posted April 29, 2019 Hi, what is the folder structure of the planet earth folder?
hazhanglei 3 Posted April 29, 2019 Author Posted April 29, 2019 Hi, what is the folder structure of the planet earth folder? This is the folder structure of my documentary.
hazhanglei 3 Posted May 5, 2019 Author Posted May 5, 2019 嗨,行星地球文件夹的文件夹结构是什么? Hello, my problem still exists after updating to 4.1.1, there is no solution, the attachment is EMBY log. Log.txt
Happy2Play 9806 Posted May 5, 2019 Posted May 5, 2019 (edited) To me this all looks like structure/unsupported naming scheme. https://github.com/MediaBrowser/Wiki/wiki/TV-naming It has been mentioned on other topics that episode folders should be added in I believe upcoming release, but your I have no idea about the way yours are named. Also if this is a new issue it would appear to be the "Improve series folder detection" applied in 4.1.0.26. Edited May 5, 2019 by Happy2Play
Luke 42219 Posted May 5, 2019 Posted May 5, 2019 There will be changes in the next 4.2 beta that may help with this.
