Angelblue05 4132 Posted May 12, 2019 Posted May 12, 2019 (edited) @@Drego344 Really strange. Are you able to access your server folder > data > syncdata > you'll see 3 json files. Can you redo the update trigger test. Just go in the webclient > 3 dots on an episode or movie > edit metadata > save. Take note of the item id in the url id={itemid}&...) Let me know what it is and provide those 3 json files. This will confirm if the Kodi companion is indeed recording events or not. We'll go from there. Edited May 12, 2019 by Angelblue05
Drego344 23 Posted May 12, 2019 Author Posted May 12, 2019 i running on freenas 11.. how would i access the server folder?
Angelblue05 4132 Posted May 12, 2019 Posted May 12, 2019 (edited) @@makarai Are you able to assist this user regarding this. I don't know anything about freenas, your help is appreciated. Thank you. @@Drego344 Really strange. Are you able to access your server folder > data > syncdata > you'll see 3 json files. Can you redo the update trigger test. Just go in the webclient > 3 dots on an episode or movie > edit metadata > save. Take note of the item id in the url id={itemid}&...) Let me know what it is and provide those 3 json files. This will confirm if the Kodi companion is indeed recording events or not. We'll go from there. Edited May 12, 2019 by Angelblue05
makarai 109 Posted May 12, 2019 Posted May 12, 2019 @@Angelblue05 @@Drego344 What is the problem? Freenas cannot scan folders on file change you have to update the library manually, or have your other tools (sonarr, radarr) setup that they query the emby library refresh.
Drego344 23 Posted May 12, 2019 Author Posted May 12, 2019 @@makarai the problem is that emby for kodi use to update when you start up kodi and process any changes between the server and kodi.... now its not processing the updates onces kodi is started
Angelblue05 4132 Posted May 12, 2019 Posted May 12, 2019 @@Angelblue05 @@Drego344 What is the problem? Freenas cannot scan folders on file change you have to update the library manually, or have your other tools (sonarr, radarr) setup that they query the emby library refresh. Can you help this user retrieve the syncdata I asked? He doesn’t know where server files are located. I’m trying to confirm the plugin is indeed recording events, because I have not changed the fast sync since 4x came out...
makarai 109 Posted May 13, 2019 Posted May 13, 2019 (edited) Sure. I assume you installed Emby via the emphasized methods, so you'll find the folder /mnt/TANK/iocage/jails/emby-server/root/var/db/emby-server/data/SyncData TANK is typically refered to as the location of your zpools for me that is /mnt/evo/iocage/jails/emby-server-beta-41010_2/root/var/db/emby-server/data/SyncData Edited May 13, 2019 by makarai 1
Drego344 23 Posted May 13, 2019 Author Posted May 13, 2019 i found the syndata folder but how do i export the json file 1
Drego344 23 Posted May 14, 2019 Author Posted May 14, 2019 @@Angelblue05 i did some testing and this is what i found out.....i shut down kodi and added a random movie to my server, when it showed up on the webclient, i reopen kodi and in a few seconds the movie was there...i did the same for tvshows and i wasnt so lucky.... so it seems like theres a problems with the kodi companion recording tvshows events.... i am still trying to get you those json, just wanted to let you know, to see if this can help... 1
Angelblue05 4132 Posted May 15, 2019 Posted May 15, 2019 @@Drego344 Can you retry with 4.0.23? Repair your libraries to be safe. Then test to see if startup updates work.
Drego344 23 Posted May 15, 2019 Author Posted May 15, 2019 no joy...i updated to 4.0.23 repaired my library and shut down kodi.....i marked some episodes as watch on the server, open kodi and they are still unwatched... is this an isolated situation, is anyone else experiencing this?
Angelblue05 4132 Posted May 15, 2019 Posted May 15, 2019 (edited) Yes, as far as I’m aware, you are indeed the only one with this issue. That’s why it’s harder to troubleshoot and why I need those files to confirm that indeed episode updates are correctly recorded by the server plugin. Edited May 15, 2019 by Angelblue05
Angelblue05 4132 Posted May 23, 2019 Posted May 23, 2019 @@Drego344 Can you retry with 4.0.25a. I discovered an error in the code that could explain what you were seeing. Fingers crossed this is resolved with the latest beta. Let me know.
Drego344 23 Posted May 23, 2019 Author Posted May 23, 2019 Still no joy.....I repaired the library and marked some episodes in the web client as watched, but they are still showing in kodI as un-watched.... Like I explained movies are fine, if kodI is open everything works perfect, if I mark something as watch it immediately update kodi... If I shut down kodi and Mark episodes as watch then open kodi, it's not synching up with the web client...only tv shows are doing this..... On a positive note while repairing my library the scan is super fast... 1
Angelblue05 4132 Posted May 23, 2019 Posted May 23, 2019 Ok, well I’m not sure what the issue could be really then. It must be with the server plugin after all, but why only tv shows? Have you been able to retrieve those file from the plugin data dir?
Drego344 23 Posted May 23, 2019 Author Posted May 23, 2019 been trying to retrieve the files but cant figure it out.
Angelblue05 4132 Posted May 23, 2019 Posted May 23, 2019 @marakai Can you tell us how to retrieve those files to post them here, please? Thank you.
Drego344 23 Posted May 24, 2019 Author Posted May 24, 2019 @@Angelblue05 will my logs help....seeing some errors emby 4208 logs.txt
Drego344 23 Posted May 24, 2019 Author Posted May 24, 2019 now i keep getting this error every time kodi start Failed to retrieve latest content updates. No content updates will be applied until kodi restarts
Angelblue05 4132 Posted May 24, 2019 Posted May 24, 2019 @@Luke What are those monitor exceptions in the previous post? Are they stopping server events from being triggered?
Luke 42237 Posted May 24, 2019 Posted May 24, 2019 If you recall I explained this before for freebsd, the mono implementation of filesystemwatcher is not fully functional. Apparently there are community patches on freebsd ports to fix it but I have no idea what the process is to integrate those. As far as the sync process is concerned, it just means you'll have to wait for the next library scan before the events will fire. 1
Angelblue05 4132 Posted May 24, 2019 Posted May 24, 2019 Ah right, apologies. It’s just strange, it only effects his tv shows. Movies are receiving updates. Ah well. Well @@Drego344 I recommend you use Embycon. You’ll have a better experience, since it will pull your content in real-time, your difficulties with tv show updates being recorded won’t have any effects.
Drego344 23 Posted May 24, 2019 Author Posted May 24, 2019 whats the difference between embycon and emby for kodi
Luke 42237 Posted May 24, 2019 Posted May 24, 2019 whats the difference between embycon and emby for kodi This is explained on our website: https://emby.media/emby-for-kodi.html Thanks !
