Trakt Logging advice
ginjaninja
2019-04-27 16:12:18.389 Info Trakt: Episodes to add to Collection: 53
2019-04-27 16:12:18.414 Info HttpClient: POST https://api.trakt.tv/sync/collection
2019-04-27 16:12:18.845 Error Trakt: TraktResponse not Found:{"ids":{"tvdb":72389,"tvrage":2454}}
2019-04-27 16:12:18.845 Error Trakt: TraktResponse not Found:{"ids":{"tvdb":72514,"tvrage":27389}}
2019-04-27 16:12:18.845 Error Trakt: TraktResponse not Found:{"ids":{"tvdb":361718}}
2019-04-27 16:12:18.845 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt7031398","tvdb":326347}}
2019-04-27 16:12:18.845 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt2117380","tvdb":259418}}
2019-04-27 16:12:18.845 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt4445154","tvdb":294801,"tvrage":44640}}
2019-04-27 16:12:18.845 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0436992","tvdb":78804,"tvrage":3332}}
2019-04-27 16:12:18.845 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0386180","tvdb":78831,"tvrage":3380}}
2019-04-27 16:12:18.845 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0092355","tvdb":75139}}
2019-04-27 16:12:18.845 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0278877","tvdb":76884,"tvrage":5125}}
Are these log lines from episodes in the emby library not matchable on trakt?
and if so, is there some episode information missing in the logging?
how does this help me track down if there is a mismatch between ids in emby and ids in trakt.?
(generally the tvdb id and imbdb id always match emby<>trakt at the show level)
bobaldis
I was having issues syncing watched Trakt status for some recently watched episodes so probably related to the update issues I've seen on numerous recent Topics, I followed the recommendation of turning off (they were selected) and on the syncing options as https://i.imgur.com/Deb31X6.png, ran a scheduled sync and also restarted the server. Somewhere through the process I lost the Emby watched status for the 3 GOT episodes I was monitoring (presumably as I'd turned off the "skip unwatched import from Trakt"). On Emby I re-enabled their watched status and ran the Trakt schedule sync task and it work so hopefully that is resolved.
But I still see silmilar entries in my logs as "ginjaninja" and also wondered what I need to do about these?:
Thanks,
Bob
2019-04-29 14:18:32.402 Info App: Application version: 4.1.0.26
2019-04-29 14:18:32.402 Info App: Emby
    Command line: /volume1/@appstore/EmbyServer/releases/4.1.0.26/EmbyServer.dll -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -ffdetect /var/packages/EmbyServer/target/ffmpeg/bin/ffdetect -restartexitcode 121
    Operating system: Unix 4.4.59.0
    64-Bit OS: True
    64-Bit Process: True
    User Interactive: True
    Runtime: file:///volume1/@appstore/EmbyServer/3rdparty/netcore/2.2.1/runtime/System.Private.CoreLib.dll
    Processor count: 4
    Program data path: /var/packages/EmbyServer/target/var
    Application directory: /volume1/@appstore/EmbyServer/releases/4.1.0.26
2019-04-29 14:18:32.402 Info App: Plugins:
    Cinema Mode 1.0.14.0
    Dlna 1.0.13.0
    Email Notifications 3.1.4.0
    Fanart.tv 1.0.2.0
    IMVDb 1.0.7.0
    Iso Mounter 1.0.3.0
    MovieDb 1.0.8.0
    MusicBrainz 1.0.5.0
    Nfo Metadata 1.0.11.0
    OMDb 1.0.5.0
    Open Subtitles 1.0.15.0
    Port Mapper 1.0.1.0
    Studio Images 1.0.0.0
    TheAudioDb 1.0.4.0
    TheTVDB 1.0.6.0
    Trakt 3.3.2.0
2019-04-29 14:18:32.402 Info TaskManager: Rotate log file Completed after 0 minute(s) and 0 seconds
2019-04-29 14:18:32.447 Info TaskManager: ExecuteQueuedTasks
2019-04-29 14:18:35.859 Info HttpServer: HTTP GET http://192.168.1.120:8096/emby/Plugins. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.103 Safari/537.36
2019-04-29 14:18:35.860 Info HttpServer: HTTP Response 200 to 192.168.1.122. Time: 2ms. http://192.168.1.120:8096/emby/Plugins
2019-04-29 14:18:35.875 Info HttpServer: HTTP GET http://192.168.1.120:8096/emby/web/configurationpages?pageType=PluginConfiguration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.103 Safari/537.36
2019-04-29 14:18:35.876 Info HttpServer: HTTP Response 200 to 192.168.1.122. Time: 1ms. http://192.168.1.120:8096/emby/web/configurationpages?pageType=PluginConfiguration
2019-04-29 14:18:37.225 Info HttpServer: HTTP GET http://192.168.1.120:8096/emby/ScheduledTasks?isHidden=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.103 Safari/537.36
2019-04-29 14:18:37.226 Info HttpServer: HTTP Response 200 to 192.168.1.122. Time: 2ms. http://192.168.1.120:8096/emby/ScheduledTasks?isHidden=false
2019-04-29 14:18:43.038 Info HttpServer: HTTP POST http://192.168.1.120:8096/emby/ScheduledTasks/Running/b1a52e63d5fb09335557d4f1e6402299. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.103 Safari/537.36
2019-04-29 14:18:43.041 Info TaskManager: Executing Sync library to trakt.tv
2019-04-29 14:18:43.041 Info HttpServer: HTTP Response 204 to 192.168.1.122. Time: 3ms. http://192.168.1.120:8096/emby/ScheduledTasks/Running/b1a52e63d5fb09335557d4f1e6402299
2019-04-29 14:18:43.068 Info HttpServer: HTTP GET http://192.168.1.120:8096/emby/ScheduledTasks?isHidden=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.103 Safari/537.36
2019-04-29 14:18:43.069 Info HttpServer: HTTP Response 200 to 192.168.1.122. Time: 2ms. http://192.168.1.120:8096/emby/ScheduledTasks?isHidden=false
2019-04-29 14:18:43.109 Info HttpClient: GET https://api.trakt.tv/sync/watched/movies
2019-04-29 14:18:43.451 Info HttpClient: GET https://api.trakt.tv/sync/collection/movies?extended=metadata
2019-04-29 14:18:45.826 Info Trakt: Movies to add to collection: 3
2019-04-29 14:18:45.962 Info HttpClient: POST https://api.trakt.tv/sync/collection
2019-04-29 14:18:46.224 Error Trakt: TraktResponse not Found:{"title":"Battlestar Galactica: Blood & Chrome","year":2013,"ids":{"imdb":"tt1704292","tmdb":257368}}
2019-04-29 14:18:46.224 Error Trakt: TraktResponse not Found:{"title":"Emilie Kempin-Spyri","year":2015,"ids":{"imdb":"tt5137810"}}
2019-04-29 14:18:46.224 Error Trakt: TraktResponse not Found:{"title":"The Marvelous Mrs. Maisel","year":2017,"ids":{"imdb":"tt5788792","tmdb":497889}}
2019-04-29 14:18:46.232 Info Trakt: Movies to remove from collection: 0
2019-04-29 14:18:46.239 Info Trakt: Movies to set watched: 0
2019-04-29 14:18:46.239 Info Trakt: Movies to set unwatched: 0
2019-04-29 14:18:46.281 Info HttpClient: GET https://api.trakt.tv/sync/watched/shows
2019-04-29 14:18:46.812 Info HttpClient: GET https://api.trakt.tv/sync/collection/shows?extended=metadata
2019-04-29 14:18:48.143 Info HttpServer: HTTP GET http://192.168.1.120:8096/emby/System/Logs. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.103 Safari/537.36
2019-04-29 14:18:48.150 Info HttpServer: HTTP GET http://192.168.1.120:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.103 Safari/537.36
2019-04-29 14:18:48.173 Info HttpServer: HTTP Response 200 to 192.168.1.122. Time: 31ms. http://192.168.1.120:8096/emby/System/Logs
2019-04-29 14:18:48.196 Info HttpServer: HTTP Response 200 to 192.168.1.122. Time: 46ms. http://192.168.1.120:8096/emby/System/Configuration
2019-04-29 14:18:49.920 Info Trakt: Episodes to add to Collection: 123
2019-04-29 14:18:50.311 Info HttpClient: POST https://api.trakt.tv/sync/collection
2019-04-29 14:18:50.822 Info HttpClient: POST https://api.trakt.tv/sync/collection
2019-04-29 14:18:51.015 Error Trakt: TraktResponse not Found:{"ids":{}}
2019-04-29 14:18:51.015 Error Trakt: TraktResponse not Found:{"ids":{"tvdb":77486}}
2019-04-29 14:18:51.015 Error Trakt: TraktResponse not Found:{"ids":{"tvdb":77513}}
2019-04-29 14:18:51.015 Error Trakt: TraktResponse not Found:{"ids":{"tvdb":140151}}
2019-04-29 14:18:51.015 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0303461","tvdb":78874}}
2019-04-29 14:18:51.015 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt1429449","tvdb":182061}}
2019-04-29 14:18:51.015 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0788121","tvdb":270182}}
2019-04-29 14:18:51.015 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt1826940","tvdb":248682}}
2019-04-29 14:18:51.015 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0098898","tvdb":76329}}
2019-04-29 14:18:51.015 Error Trakt: TraktResponse not Found:{"ids":{"tvdb":6498043}}
2019-04-29 14:18:51.015 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0397850","tvdb":127411}}
2019-04-29 14:18:51.016 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0397850","tvdb":127411}}
2019-04-29 14:18:51.023 Info Trakt: Episodes to remove from Collection: 2
2019-04-29 14:18:51.039 Info HttpClient: POST https://api.trakt.tv/sync/collection/remove
2019-04-29 14:18:51.290 Info Trakt: Episodes to set watched: 1
2019-04-29 14:18:51.342 Info HttpClient: POST https://api.trakt.tv/sync/history
2019-04-29 14:18:51.533 Info Trakt: Episodes to set unwatched: 0
2019-04-29 14:18:51.536 Info TaskManager: Sync library to trakt.tv Completed after 0 minute(s) and 8 seconds
