pwhodges 2028 Posted May 11, 2019 Posted May 11, 2019 (edited) how did you move it? It's in the Hauppauge settings, on the capture tab (it's not an Emby thing, so you use WinTV to change it). Edited May 11, 2019 by pwhodges
Gyp Joe 2 Posted May 11, 2019 Author Posted May 11, 2019 It's in the Hauppauge settings, on the capture tab (it's not an Emby thing, so you use WinTV to change it). got it - thanks again
Gyp Joe 2 Posted May 16, 2019 Author Posted May 16, 2019 Can you please provide a single server log file from the time that a recording should have happened? Thanks. She had a really good run with no failures for at least five days - now it's back, failing consistently... I record Global News @ 6pm daily - log attached embyserver-63693542788.zip
Luke 42221 Posted May 20, 2019 Posted May 20, 2019 There was an error opening the tuner. Was it already in use at the time?
Gyp Joe 2 Posted May 21, 2019 Author Posted May 21, 2019 I don't believe so and only Emby is running on this server. I'm wondering if it is still hanging on to the tuner from the previous recording like Hodges was saying. That would explain why it works again after a boot. Thanks
