embymike 0 Posted April 25, 2019 Posted April 25, 2019 Hello all, I am behind the times, and recently tried to upgrade a working emby 3.5.3.0 installation on Debian 9 (x64). I downloaded emby-server-deb_4.2.0.1_amd64.deb from emby.com/downloads and ran sudo dpkg -i emby-server... The package appears to load, but sudo systemctl status emby-server.service shows: ● emby-server.service - Emby Server is a personal media server with apps on just about every device. Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: failed (Result: signal) since Thu 2019-04-25 08:38:10 EDT; 40s ago Process: 12660 ExecStart=/opt/emby-server/bin/emby-server (code=killed, signal=ABRT) Main PID: 12660 (code=killed, signal=ABRT) Apr 25 08:38:09 Enterprise emby-server[12660]: --- End of inner exception stack trace --- Apr 25 08:38:09 Enterprise emby-server[12660]: at System.IO.FileSystem.CreateDirectory(String fullPath) Apr 25 08:38:09 Enterprise emby-server[12660]: at System.IO.Directory.CreateDirectory(String path) Apr 25 08:38:09 Enterprise emby-server[12660]: at Emby.Server.Implementations.Logging.FileLogger..ctor(String path) Apr 25 08:38:09 Enterprise emby-server[12660]: at Emby.Server.Implementations.Logging.SimpleLogManager.ReloadLogger(LogSeverity severity, CancellationToken cancellat Apr 25 08:38:09 Enterprise emby-server[12660]: --- End of inner exception stack trace --- Apr 25 08:38:09 Enterprise emby-server[12660]: at System.Threading.Tasks.Task.WaitAllCore(Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToke Apr 25 08:38:10 Enterprise systemd[1]: emby-server.service: Main process exited, code=killed, status=6/ABRT Apr 25 08:38:10 Enterprise systemd[1]: emby-server.service: Unit entered failed state. Apr 25 08:38:10 Enterprise systemd[1]: emby-server.service: Failed with result 'signal' sudo systemctl start|restart emby-server.service fails to start it, When I do dpkg -P emby-server... to uninstall, then I re-install 3.5.3, the old version works again. I'm clueless. I did my best to scour the forums here. I tried removing the emby user and group before installation. No luck. I cannot find any emby log files, since it appears emby never starts. I've tried emby versions 4.0.1.0, 4.1.0.26, 4.2.0.1. Nothing in the 4's works. Thanks for any advice! Mike
Luke 42246 Posted April 25, 2019 Posted April 25, 2019 Strange. It seems to suggest there's no write access to the logs directory.
bellocarico 4 Posted April 26, 2020 Posted April 26, 2020 Strange. It seems to suggest there's no write access to the logs directory. Oh.... well spotted, Not sure why this has happened though! Fixed manually now it works again! Many thanks!
al92780 7 Posted October 20, 2020 Posted October 20, 2020 I have same problem. Can you identify the specific files you changed? Thks al
Luke 42246 Posted October 20, 2020 Posted October 20, 2020 16 minutes ago, al92780 said: I have same problem. Can you identify the specific files you changed? Thks al
