schmitty 66 Posted April 25, 2019 Posted April 25, 2019 Hello, Could audio codec detection be improved for Emby Server? The below is Atmos MediaInfo taken from Minions: Audio #1 ID : 2 Format : MLP FBA 16-ch Format/Info : Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Codec ID : A_TRUEHD Duration : 1 h 30 min Bit rate mode : Variable Bit rate : 5 262 kb/s Maximum bit rate : 7 269 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 1 200.000 FPS (40 SPF) Compression mode : Lossless Stream size : 3.34 GiB (14%) Title : English - Dolby Atmos 7.1 Language : English Default : Yes Forced : No Number of dynamic objects : 11 Bed channel count : 1 channel Bed channel configuration : LFE When displayed in Emby, there is no mention of Dolby Atmos, only TRUEHD The below is DTS-X MediaInfo taken from Despicable Me 3: Audio #1 ID : 2 Format : DTS XLL X Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Codec ID : A_DTS Duration : 1 h 29 min Bit rate mode : Variable Bit rate : 3 595 kb/s Channel(s) : 8 channels Channel(s)_Original : Object Based Channel layout : Object Based Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Stream size : 2.25 GiB (12%) Title : English - DTS-X 7.1 Language : English Default : Yes Forced : No When displayed in Emby, there is no mention of DTS-X, only DTS The below is DTS-HD MA MediaInfo taken from Forgetting Sarah Marshall: Audio #1 ID : 2 Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Codec ID : A_DTS Duration : 1 h 57 min Bit rate mode : Variable Bit rate : 3 927 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossless Stream size : 3.23 GiB (16%) Title : DTS-HD MA 5.1 English Language : English Default : Yes Forced : No When displayed in Emby, there is no mention of DTS-HD MA, only DTS Dolby Atmos, DTS-X and DTS-HD MA as well as other DTS codecs (eg. DTS-HD, DTS-HD HRA) need to be displayed correctly in the audio select drop-down menus. Not the core codec names DTS and TRUEHD.
Luke 42217 Posted April 25, 2019 Posted April 25, 2019 Hi, we do have auto-detection. That's just the information that we get from ffmpeg. Hopefully in a future update they'll provide more detail so that we can do that. Thanks.
Guest asrequested Posted April 25, 2019 Posted April 25, 2019 Part of the problem is that Atmos and DTS-X are metadata and not codecs. ffprobe doesn't report them, at this time.
schmitty 66 Posted April 25, 2019 Author Posted April 25, 2019 Is it possible to use MediaInfo for this?
Luke 42217 Posted April 25, 2019 Posted April 25, 2019 Not exactly. Since we end up relying on that media info with ffmpeg for transcoding, it's best if we use the same application for both transcoding and media info gathering.
schmitty 66 Posted April 26, 2019 Author Posted April 26, 2019 Fair enough. I guess we just have to wait for ffmpeg to get their act together, and correctly report the metadata.
TonioRoffo 4 Posted September 19, 2019 Posted September 19, 2019 This is quite different in Plex, for example. Atmos & DTS-X not being detected, that's normal, that's embedded in the audio stream. But Dolby TrueHD (Emby & Plex) and DTS-HD (Plex only) should be able to be detected in metadata, no?
schmitty 66 Posted September 19, 2019 Author Posted September 19, 2019 I don’t know what ffmpeg’s issue is. Atmos is detected by MediaInfo as Format: MPL FBA 16-ch Format/Info: Meridian Lossless Packing FBA with 16-channel presentation Commercial name: Dolby TrueHD with Dolby Atmos Number of dynamic objects: 11 Sent from my iPhone using Tapatalk
Luke 42217 Posted September 19, 2019 Posted September 19, 2019 This is quite different in Plex, for example. Atmos & DTS-X not being detected, that's normal, that's embedded in the audio stream. But Dolby TrueHD (Emby & Plex) and DTS-HD (Plex only) should be able to be detected in metadata, no? We can already detect TrueHD and Dts-HD.
