Michael.D.Pine 4 Posted April 25, 2019 Posted April 25, 2019 What is the suggestion for setting a default recording path, do people generally create a share folder and store the recordings there ? Or just use the default path ? If it is a share folder or folder on the NAS raid drives how to I specify in the folder location in the text box in the attached file ? This is my first time installing this on my NAS so never configured anything like this before ? I assume if I install another client on another machine I just connect it to that Emby Server and it will have access to all the recordings but I would like the recordings to go into a Share folder or folder on the actual RAID drives and not on the NAS O/S storage. thanks Michael
PenkethBoy 2068 Posted April 26, 2019 Posted April 26, 2019 I created a share "EmbyProgData" so mine look like this Use the search icon (magnifying glass) to pick the directory I dont fill in the default path as it will create an extra library on the home page which wont get used
Luke 42241 Posted April 28, 2019 Posted April 28, 2019 Please let us know if this helps. We need to improve these settings and make them easier to understand. Thanks.
Michael.D.Pine 4 Posted April 29, 2019 Author Posted April 29, 2019 Will do, just have to give me some time though, I think I actually do have it set up I will try and test some recordings tonight and see if it works ok and then connect from a different device, it's just currently the main tv/setup is now in Production use, so if I tell my wife I have to take it away for a while, I will be killed.....
