kesm 25 Posted June 27, 2019 Posted June 27, 2019 I'm a noob, dark image was because I paused the episode to take a screenshot sorry.Strange thing, I tried each version until the 4.1.1.0 and now subtitiles are working if I play episode from the beginning. BUT if I move to play the episode 10 minutes after the beginning, subtitiles will never load
theghost31 4 Posted June 27, 2019 Posted June 27, 2019 (edited) @@kesm, Can you try 4.1.0.15 please ? Subtitles are they messed up like in 4.1.1.0 ? If you try again 4.1.0.14, is it ok ? Like that we can told to Luke to look it, because on my issue, I didn't have the chance to give to him an example because I deleted by mistake the file with this issue --" I tried each version until the 4.1.1.0 and now subtitiles are working if I play episode from the beginning. BUT if I move to play the episode 10 minutes after the beginning, subtitiles will never load And I think it's worse than you think. In my case, at the beginning, I got sometimes subtitles and soudently 4min after something like that, no subtitles, you wan try to restart, read from the begin, jump until this timing, the subtitles gones ... You will tell me if you get it the same behavior I'm a noob, dark image was because I paused the episode to take a screenshot sorry. It happens Edited June 28, 2019 by ebr language
kesm 25 Posted June 28, 2019 Posted June 28, 2019 Yes I think it's the same proble. It works if trying from the beginning (in all versions) but doesn't work if you move in time (since 4.1.0.15), I didn't try a whole episode so I didn't know if subtitles will stop working randomly, I'm currently using plex only for these files...
theghost31 4 Posted July 17, 2019 Posted July 17, 2019 (edited) @@Luke, any news about this issue, near with mine ?Always happens with latest beta availableThank you Edited July 17, 2019 by theghost31
Paxalou 4 Posted August 6, 2019 Posted August 6, 2019 (edited) Hi, same problem here with 4.2.0.40 version of emby server. PGS are fine. SRT are not showing. How can I go back to a previous version which work fine with SRT ? EDIT : found ! I have the SRT now showing, because I've donwgraded to 4.0.2.0 Maybe it's not the best stable version. Which one should I use ? Edited August 6, 2019 by Paxalou
theghost31 4 Posted August 6, 2019 Posted August 6, 2019 I think it's the better version that can have with the stable version. In beta version, it's 4.1.0.14. After that, you will have some trouble
Paxalou 4 Posted August 6, 2019 Posted August 6, 2019 (edited) OK, thanks ! I don't find 4.1.0.14 for linux deb AMD64. Could you tell me where to download it ? Edited August 6, 2019 by Paxalou
theghost31 4 Posted August 6, 2019 Posted August 6, 2019 (edited) Mhh sorry, I'm using Docker to install emby, so I specify a version and the magic happens ^^ Edited August 6, 2019 by theghost31
Paxalou 4 Posted August 6, 2019 Posted August 6, 2019 Ok. But now, it strange, my library does not scan my subfolders...
Paxalou 4 Posted August 7, 2019 Posted August 7, 2019 (edited) Bonjour, Avec l'application Web, lorsque je lis une vidéo mkv, contenant un fichier de sous-titre au format SRT, celui-ci s'affiche uniquement si je regarde le film depuis le début. Dès que je veux naviguer dans le film, ces sous-titres ne s'affichent plus. Il n'y a cependant aucun problème pour des sous-titres de format PGS. J'utilise la web app sous Firefox (Linux) Ma version de Emby Sevrer est 4.2.0.40 (Linux DEB AMD64) Je crois que ce problème est déjà connu des développeurs. J'ai tenté de rétrograder, mais alors, il y a d'autres bugs qui apparaissent (par exemple, les sous-dossiers ne sont pas scannés). Est-ce qu'un correctif est prévu concernant ces sous-titres ? Edited August 7, 2019 by Paxalou
Luke 42217 Posted August 7, 2019 Posted August 7, 2019 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks.
Paxalou 4 Posted August 8, 2019 Posted August 8, 2019 (edited) Ok. J'ai effectué une lecture de la vidéo directement à 40 minutes, et les sous-titres n'apparaissent pas (pourtant, ils sont bien sélectionnés). Voici les logs (il y avait deux logs de transcodage). Je n'ai pas de screenshots à poster, car il n'y a rien de particulier à l'écran. Simplement, il n'y a pas de sous-titres. Il n'y a pas non plus de message d'erreur dans la Web App. Précision: si je passe par Kodi, en utilisant l'extension "Emby for Kodi", je n'ai pas ce problème. Embyserver.txt ffmpeg.transcode.1.txt ffmpeg.transcode.2.txt Edited August 8, 2019 by Paxalou
Paxalou 4 Posted August 18, 2019 Posted August 18, 2019 Misé à jour effectué vers la 4.2.1.0. Le problème est toujours présent.
Luke 42217 Posted September 10, 2019 Posted September 10, 2019 Please try this again when Emby Server 4.3 is released. Thanks.
Paxalou 4 Posted October 14, 2019 Posted October 14, 2019 (edited) I tried with beta 4.3.0.14, and the problem stil remains... The two only ways to have subtitles are : 1. Just play the movie from the beginning, and NEVER go forward. 2. Download srt from Opensubtitles (hoping the srt exists on the site...) Edited October 14, 2019 by Paxalou
Luke 42217 Posted October 14, 2019 Posted October 14, 2019 I tried with beta 4.3.0.14, and the problem stil remains... The two only ways to have subtitles are : 1. Just play the movie from the beginning, and NEVER go forward. 2. Download srt from Opensubtitles (hoping the srt exists on the site...) @@Paxalou can you provide a sample video for testing? Thanks.
Paxalou 4 Posted October 15, 2019 Posted October 15, 2019 Ok, but are samples protected by any copyright ? I mean, is it legal to post here a sample of a movie ?
