syralk 13 Posted April 24, 2019 Posted April 24, 2019 Hi, It seem that LIVE TV stream MP2 video stream are harder remotely on Fire TV I was just wondering if it was a way to force encoding MP2 to h.264 to reduce the size of the stream. thanks
denz 501 Posted April 29, 2019 Posted April 29, 2019 (edited) @@syralk I think there isn't an option for MP2 content. You are probable aware of these things In the server settings under Advanced you can edit Internet streaming bitrate limit (Mbps): which will force transcode this applies to all users and all the content or if you go to settings of the app that you are using you can change the bitrate it is probable set to auto so you may lower this to say 15mbps. Edited April 29, 2019 by denz
Luke 42246 Posted April 29, 2019 Posted April 29, 2019 Are you sure it's direct streaming to the app?
syralk 13 Posted April 29, 2019 Author Posted April 29, 2019 Are you sure it's direct streaming to the app? I'll double check on a remote application
