arche 177 Posted March 5, 2023 Author Posted March 5, 2023 Release 20230303: ATSC3 models: Detect ATSC 3.0 protected channels. ATSC3 models: Support RTP radio channels. ATSC3 models: Support operation when S-TSID content type is missing. ATSC3 models: Report BSID/TSID in streaminfo if present. ATSC3 models: Reorder audio tracks for apps that use the first track rather than selecting the audio track by language. ATSC3 models: Improvements to MP4 parsing. IPv6 models: Support IPv6 RTP/UDP target. TECH models: Fix problem where target may not be set when specified in the boot script. Fix problem where multicast traffic was sent with a TTL of 1. Improvements to diagnostic logging. Firmware Changelog 2
arche 177 Posted March 24, 2023 Author Posted March 24, 2023 Release 20230323: ATSC3 models: Fix problem where channel scan may not detect some ATSC 3.0 channels. ATSC3 models: Fix problem where channels using MMTP transport may fail to tune or stall shortly after tuning. ATSC3 models: Fix problem where one or more elementary streams such as audio may be missing. ATSC3 models: Fix problem where ATSC 3.0 HD channels were not detected as HD by the channel scan. IPv6 models: Support detection via IPv6 site-local multicast. Record models: Support discovering tuner and record engines via IPv6 site-local multicast when an IPv6 global or site-local IP address is present. Record models: Upgrade to 64-bit identifiers for recorded files. Firmware Changelog 1
arche 177 Posted May 5, 2023 Author Posted May 5, 2023 Release 20230503: ATSC3 models: Detect content protection for stations that are protecting content but not indicating so in the LLS. ATSC3 models: Optimize starting PLP selection as detected during channel scan. ATSC3 models: Add round-trip-time validation support needed for ATSC 3.0 protected channels. ATSC/ISDBT models: Ignore OTA channels without virtual channel numbers. DVB models: Fix channel scan issue causing BBC One HD in the UK to detect as Unknown. Fix bug in handling of the OriginalNetworkID in lineup.xml. Disallow the use of 255.255.255.255 UDP broadcast for video. Improvements to channel scan handling. Firmware Changelog 1 1
rbjtech 5341 Posted May 5, 2023 Posted May 5, 2023 (edited) 1 hour ago, arche said: Release 20230503: DVB models: Fix channel scan issue causing BBC One HD in the UK to detect as Unknown. Nice - I wondered when they would fix this.. thanks ! Before update .. After update .. A quick Refresh of Guide Data has it all synced again. Edited May 5, 2023 by rbjtech 1
arche 177 Posted May 8, 2023 Author Posted May 8, 2023 Release 20230505: Legacy models: Disallow the use of 255.255.255.255 UDP broadcast for video. Record models: Fix issue introduced in 20230503 recording from non-ipv6 models. Firmware Changelog
arche 177 Posted July 15, 2023 Author Posted July 15, 2023 Release 20230713: ATSC3 models: Support detecting and reporting ATSC 3.0 parental rating information. ATSC3 models: Support alternative way resolution is reported by some ATSC 3.0 stations. ATSC3 models: Support alternative way track media types are reported by some ATSC 3.0 stations. ATSC3 models: Support detecting descriptive audio tracks on ATSC 3.0 channels. ATSC3 models: Support trex dafaults required by some ATSC 3.0 test streams. ATSC3 models: Support 2-character language codes on ATSC 3.0 channels. ATSC3 models: Nextgen TV certification release candidate. ISDB-T models: Fix problem detecting virtual channel numbers on cable systems that use DVB style channel numbers. Add Access-Control-Origin header when delivering video over http. Firmware Changelog 1
rbjtech 5341 Posted June 6, 2025 Posted June 6, 2025 Release 20250506: Fix compliance issues with MDNS handling causing spurious traffic and other issues. Configure UPNP to announce services using the primary IPv4 and primary IPv6 address only. Add signal strength/quality to the channel scan results. ATSC3 models: Fix problem where ATSC 3.0 channels found on one physical channel could false-detect on the next physical channel. ATSC3 models: Fix problem where incorrect parental rating could be applied on ATSC 3.0 channels. ATSC3 models: Fix issue in multi-representation support that was preventing a 4K test broadcast from playing. ATSC3 models: Add support for ATSC 3.0 content that identifies as Dolby Vision. HDFX/HDVR/HHDD models: Improve handling of a failing hard drive. TECH5: Auto-restart demodulation when needed on older ATSC1-only models. TECH5/4K-DEV models: Fix problem with ATSC 3.0 “forward” output format where power-save mode could activate stopping operation Firmware Changelog – Silicondust 2
